  • SN95 4.6L Mustang Tech
clutch, how do you know when...
  • Thread starter Thread starter screamin gt
  • Start date Start date Apr 24, 2007
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Apr 24, 2007
  • Apr 24, 2007
since the engine is out I'm thinking maybe I should replace the clutch too. never done a clutch on a car, only bikes, so I don't know what I'm looking for as far as whether or not its worn out.
or do you only need to replace it if its broken?
T
tradde
94
Pennsylvania
Apr 24, 2007
  • Apr 24, 2007
Well, since it's out of the car already you can measure the clutch thinkness
and check that against the original. You should also check the flywheel and
pressure plate for any warping or burned spots. A clutch isn't that expensive
and if it was me and it was already out I'd just replace now. If you end up
having to replace it later you have to remove the tranny. Just my opinion.'
Tim
D
Dragstr05
643
Stafford VA
Apr 24, 2007
  • Apr 24, 2007
Of all the clutches I've done, I've never seen a clutch disc that completely wore the material down - the clutch is just slipping and thats why they were getting replaced. If you want to get an idea of how much life is left, just find out what the disc thickness spec is and measure your clutch when its out. You can also get a rough idea by seeing how far from the surface the rivets are. If its too close for comfort, replace it. If you have alot of hotspots or scoring, by all means replace it.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
