clutch in 01 cobra???
somewhat
My clutch is stiffer than my 99 GT was but not as bad as the clutch was in my 88 5.0.
You may want to consider an aftermarket clutch quadarant and firewall adjuster. Then you can dial in the preload for the clutch as well as having a much smoother path for the clutch cable instead of the stock plastic on plastic gears.
I am convinced Fiore makes the best kit for this on the market, but anything is better than the stock setup. :nonono:
