I just did mine 2 weeks ago in the garage, on my back, well its not hard but it helps if you have air tools and an impact to remove the flywheel bolts or your going to need a flywheel holder from MAC or Snap-On, you should also get a pilot bearing remover, other that that its all staright forward with no surprises other than the starter is kinda haed to accses but you should be ok also grain the tranny before you remove the driveshaft so it doesent make a mess. Get a Hayes manual at autozone it explains everything step by step.
