Clutch install
  • Thread starter Thread starter Paul Randle
  • Start date Start date Dec 8, 2012
Paul Randle
87
orlando
Dec 8, 2012
  • Dec 8, 2012
So i am having the clutch installing in my mustang n i am having this "mobile mechanic" do it. He said i should also change the "rear main seal" cause its a few extra bolts in the same area. Later that night i spoke to a guy at my job n he said that if this "mobile mechanic" installs the seal wrong it will cause my motor to knock. is that true?? I am super worried about this install after hearing that.
Incon
88
Dec 8, 2012
  • Dec 8, 2012
The rear main seal is super easy to put in. The hard part is getting to it. He is already going to be there with the clutch, flywheel, and pilot bearing/bushing. A firewall adjuster, new cable and an aluminum quadrant is always a good idea. NAPA sells a nice cable , btw.
Paul Randle
87
orlando
Dec 8, 2012
  • Dec 8, 2012
cool man thanks for the advice. still super nervous about the whole thing
squekster
55
long island
Dec 8, 2012
  • Dec 8, 2012
Engine knock is caused by too much advance in timing, poor fuel quaility, carbon build up in combustion chamber. The only thing that could possibily happen is an oil leak which is not good either. Don't worry if this guy is a good mechanic there shouldn't be a problem. I did mine with no problems. I would suggest you change the input bearing retainer for a steel one If your car has some miles on it, it is on its way out. The factory ones are alum.
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Dec 10, 2012
  • Dec 10, 2012
installed wrong will leak oil .... motor will not knock unless the reasons listed above or runs too low on oil from the leak I wouldn't be worried
Reactions: f8tlfiveo
xracer22
102
18
29
york pa
Dec 10, 2012
  • Dec 10, 2012
Yea the only thing i would be worried about is the "mobile mechanic" thing!! Kinda like the dentist coming to my house to pull teeth. lol kinda weird
xracer22
102
18
29
york pa
Dec 10, 2012
  • Dec 10, 2012
oops sorry bout that squekster i meant too quote that
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Hello from Washington State!
  • Daddys Lil Filly
  • Jun 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 10, 2026
Daddys Lil Filly
A
Remake Clutch and Transmission Suggestions for a 2014 6 spd manual
  • adamchrysler
  • Jul 30, 2025
2010 - 2014 Specific Tech Aug 8, 2025
SuperCharged_Coyote
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
