  • SN95 4.6L Mustang Tech
Clutch is going out??
  • Thread starter Thread starter slvr00gt
  • Start date Start date Nov 23, 2004
slvr00gt
164
Denver area
Nov 23, 2004
  • Nov 23, 2004
After driving for a while my car begin to jerk hard under load. There is no acomponying noises. Is it clutch starting to go?
Premium Speed
1,006
Houston, Texas
Nov 23, 2004
  • Nov 23, 2004
i personally don't think it is your clutch...you might want to have a mechanic take a look, that sounds bad...the clutch will usually slip under load if it is worn out
slvr00gt
164
Denver area
Nov 23, 2004
  • Nov 23, 2004
How would you describe car behavior during clutch slip under load?
My car has 95,000 on original clutch with good few drag strip trips. I would love to believe it is just the clutch
SunburstGoldGT
133
Blacksburg, VA
Nov 23, 2004
  • Nov 23, 2004
Im gettin my new one in this week sometime hopefully, the symptoms(sp?) of a clutch slip are basically you get on it and the rpms raise but your car doesnt move. Its easiest to tell on my 1-2 shift, ill shift and the rpms will go to 4g's before the damn thing catches... It doesnt ever jerk though, so i doube the clutch is it.
w00t
334
Arlington TX
Nov 23, 2004
  • Nov 23, 2004
My clutch was hard to press right before it went out.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 23, 2004
  • Nov 23, 2004
It's a great time to upgrade to a Centerforce DF Clutch!
I would have your stang looked at to know for sure.
slvr00gt
164
Denver area
Nov 23, 2004
  • Nov 23, 2004
I already have SPEC 1 clutch. I bought it two years ago thinking that with all the drag strips it is not going last much longer. Suprisingly it lasted. I will install it this weekend, hoping for the best but preparing for the worst
slvr00gt
164
Denver area
Nov 23, 2004
  • Nov 23, 2004
I already have SPEC 1 clutch. I bought it two years ago thinking that with all the drag strips it is not going to last much longer. Suprisingly it lasted. Today, I got clutch cable, all bearings and seals. I will install it this weekend, hoping for the best but preparing for the worst
When I was driving from work today it did seem more like what you guys are describing. RPMs increased while car didn't accelerate well under load. Also, clutch pedal is a lot heavier now then it used to be, but that might be the worn out cable problem
T
Drivetrain Take a look at this clutch pedal
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
