  • 1994 - 1995 Specific Tech
clutch is going
  • Thread starter Thread starter BlackVert
  • Start date Start date Oct 28, 2004
BlackVert
5,589
9
98
Bethesda, MD
Oct 28, 2004
  • Oct 28, 2004
i'm pretty sure my clutch is going. when i am starting from a stop, i can hear squeaking and rattling when i let the pedal out. it does not seem to slip, but i have been driving very gently lately, so i don't know for sure if it would slip if i tried to make it slip.
it just started doing this the last few days.
i do not have the experience to try to take it on, and even if i could do it myself, the way things have been going lately, i do not have the time to do the work myself anyway.
how long do i have to shop around before it fails? this is my daily driver and i cannot take a chance on it failing and getting stranded somewhere. my wife would say "i told you not to buy that p.o.s"
i called the shop and they said for parts and labor it would cost $575 to fix it. is that reasonable? he said that includes the pressure plate, throw out bearing, and something else i can't remember right now.
or is there anyone in the DC area who feels like helping out a fellow stanger? i'll make it worth your time.
thanks, chris
flyboy_323
57
San Luis Obispo, CA
Oct 28, 2004
  • Oct 28, 2004
$575 sounds a tad bit high, but that's about right. make sure you or they take the flywheel to a machine shop to have it resurfaced.
BlackVert
5,589
9
98
Bethesda, MD
Oct 29, 2004
  • Oct 29, 2004
it was done today. aamco wanted 850 for the job, so i just bit the bullet and paid the other guy. $580 all told.
now i just broke my back window, so there goes a few hundred more. ugh.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Oct 30, 2004
  • Oct 30, 2004
is that a must do? resurface the flywheel when swapping clutches? Where can I buy another one?
BlackVert
5,589
9
98
Bethesda, MD
Oct 30, 2004
  • Oct 30, 2004
it depends on the condition of the flywheel. mine didn't need it. i have heard though that you shouldn't get it resurfaced, you should get a new one instead.
HISSIN50
34
129
Oct 30, 2004
  • Oct 30, 2004
a flywheel should always be resurfaced, unless one likes diminished clutch life, performance and a slipping clutch.
a Blanchard grinder is the best way i know of to resurface a stang flywheel. some guys use shims after the resurface, many dont.
good luck. on foxes, new flywheels can be had for ~100 bucks.
BlackVert
5,589
9
98
Bethesda, MD
Oct 30, 2004
  • Oct 30, 2004
thing is, it was the TOB and pressure plate that went bad, the disk was ok still. and it wasn't slipping at all.
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
