  • 1994 - 1995 Specific Tech
clutch or what?
  • Thread starter Thread starter chrismillion
  • Start date Start date Nov 28, 2004
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Nov 28, 2004
the stang made an awful noise this morning when i crunk it. noise died down, and i drove about 30 miles to a nearby town. stopped car for about 3 hour and i crunk it up and the sound was back. stepped on the clutch and the sound heightened. a sqeal and grind, the sound of the grind is similar to brake pads going out. is this the clutch or what? thanks
HISSIN50
34
129
Nov 28, 2004
  • Nov 28, 2004
what is crunking?
how is your TOB? based on what you said, that would be my first guess.
good luck.
RIO5.0
6,892
N.H.
Nov 28, 2004
  • Nov 28, 2004
HISSIN50 said:
what is crunking?
good luck.
What he said.... from your description, squeeling ang grinding...she's almost toast..
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Nov 28, 2004
what a TOB?
RIO5.0
6,892
N.H.
Nov 28, 2004
  • Nov 28, 2004
throw out bearing
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Nov 28, 2004
so should i just replace that or what? and how hard is the job, for a novice?
RIO5.0
6,892
N.H.
Nov 28, 2004
  • Nov 28, 2004
Its not uncommon for them to waer out...if the miles arent to high and the clutch seems to be ok, then just swap out the bearing....money thing I guess..the TOB is under 20.00..
gotta pull the shifter, drop the DS, pull the tranny out...swap out the bearing...its fairly straight forward...you may wanna have someones whos done that kinda stuff if its your first time...depends on your wrenching i guess...shop would prolly charge 150.00 min to do it...maybe more??
DFG 5OH
1,341
Louisville, KY
Nov 28, 2004
  • Nov 28, 2004
tahts what my tranny is doing, 128,000 on a stock clutch and TOB!
BlackVert
5,589
9
98
Bethesda, MD
Nov 28, 2004
  • Nov 28, 2004
mine was making the same noise about 3 weeks ago. i ended up getting a new clutch and TOB. now it is done and no more worries about it.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 29, 2004
#10
  • Nov 29, 2004
  • #10
Sounds like your throwout bearing!
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
#11
  • Nov 29, 2004
  • #11
it was the throwout bearing. i had the entire clutch kit put in anyway. 175 dollars worth of labor. the clutch don't feel as tight anymore, what's up with that? is it suppose to be tight or loose, or is it the driver's preference and it can be adjusted accordingly?
Killercanary
The car that set the bar.
Altoona, PA
Nov 30, 2004
#12
  • Nov 30, 2004
  • #12
I don't know what you mean by tight? Most aftermarket clutches have a heavier pedal feel than the stocker, perhaps you had an aftermarket in there and who ever did the instal put a stock replacement back in. If you still have the stock quadrant, simply pull up on the clutch pedal to adjust it, if you hear it click then it needed adjusted, if not then its fine.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
