U2SLO450 Member May 27, 2006 118 0 16 Aug 6, 2007 #1 Aug 6, 2007 #1 I noticed the other day when i take off from a stop the clutch pedal makes a small "creaking" noise as i let up on it. Anyone have any ideas what this may be?
NKau Founding Member Dec 15, 2001 1,346 0 37 Jefferson, WI Aug 6, 2007 #2 Aug 6, 2007 #2 Probably just the plastic quadrant. As they wear, they can get squeaky.
Foxfan88 My Grandpa has great wood. Sep 13, 2004 2,487 4 0 Miami, Ok Aug 6, 2007 #3 Aug 6, 2007 #3 grab a can of wd-40 and spray it all over the quadrant and see if that helps
Jzava50 New Member Jun 27, 2007 15 0 0 Syracuse ,ny Aug 8, 2007 #4 Aug 8, 2007 #4 where do you find the quadrent...mine does that too!!
Foxfan88 My Grandpa has great wood. Sep 13, 2004 2,487 4 0 Miami, Ok Aug 8, 2007 #5 Aug 8, 2007 #5 crawl under the dash on the driver side there is a big half moon plastic thing. that the clutch cable wraps around.
blackened88lx Active Member Aug 9, 2006 0 4 28 Connecticut Aug 9, 2007 #6 Aug 9, 2007 #6 Get some cable lube and lube the cable while you're at it. Lube all pivot points too.
Lyonmt Member Nov 17, 2004 110 7 18 Tampa, FL Aug 9, 2007 #7 Aug 9, 2007 #7 Foxfan88 said: crawl under the dash on the driver side there is a big half moon plastic thing. that the clutch cable wraps around. Click to expand... It can be hard to see, but it is on the side closest to the radio, above the accelarator pedal. Yes, the clutch cable is directly above the gas pedal.
