Clutch pedal problems
  • Thread starter Thread starter big_tiger15
  • Start date Start date Feb 12, 2006
big_tiger15
88
Arlington, Texas
Feb 12, 2006
  • Feb 12, 2006
Last night as I was driving home The clutch pedal started to act funky. It would stick just before the clutch would start to engage. I was going to put it off till monday, but the morning when I was driving off to work. It got worse overnight!!!! I would pretty much have to lift my foot off the pedal to get it to come out. I stuck my head up under the dash and I couldnt see anything work, but I cant really see much. I did find a lil piece of of a plastic tab down in the floor board. It sounds like metal is grinding on metal.
I would like to get this fixed before I go to school and work tommorrow!!!
V
v8only
2,378
22
49
Feb 13, 2006
  • Feb 13, 2006
That could be anything from a bad cable to clutch problems.
try disconnecting your cable, and depressing the clutch fork to the floor at the transmission. (may need to lay with your head at the rear end and use your foot to depress the fork. use JACKSTANDS> if it sticks, you've got clutch issues, if not, you've got clutch cable issues.
more than likely it's your clutch cable, but no promises there.
link in my sig has all kinds of good info on this subject.
buyfordracing.com will get you an oem clutch cable and brand new clutch fork to your door for $48
HISSIN50
34
129
Feb 13, 2006
  • Feb 13, 2006
It sounds like your quadrant/pawl are coming apart. Dont be surprised if the clutch pedal stops actuating the clutch pretty soon.
A pic of the piece of plastic you found would probably help.
Good luck.
V
v8only
2,378
22
49
Feb 13, 2006
  • Feb 13, 2006
good point.
if the piece is slightly yellowed it's probably the quadrant.
big_tiger15
88
Arlington, Texas
Feb 13, 2006
  • Feb 13, 2006
Good luck.
The piece of plastic I found.
the rubber bushing thing?
now its messing up my MM firewall adjuster
I know it has to do with that bushing but I have no idea how and where it is supposed to go.
big_tiger15
88
Arlington, Texas
Feb 13, 2006
  • Feb 13, 2006
Should that pin (circled in teal) be al the way over to the right?
big_tiger15
88
Arlington, Texas
Feb 13, 2006
  • Feb 13, 2006
AH HA!! I found the problems....
That black rubber bushing is circled on the right.
This is that black rubber bushing
I would put money on my guess, but this is the old firewall grommet thing. My car is plagued by the previous owner. This rubber grommet has always been stuck on my clutch lever, since I have owned this car.
That wasnt the only problem, though.
MM firewall adjusters are a POS. It will keep backing off the cable and it backed off so much that back of the quadrant was sticking on the firewall adjuster. I would recommend a locking firewall adjuster.
I modified my MM adjuster by putting a jam bolt in the piece that bolts to the firewall, but that even backs off
Needless to say my clutch is alot easier to push in and out.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 13, 2006
  • Feb 13, 2006
Fix what's obvious first.
WTF, mine doesn't have that bushing at all. Hmmm.
big_tiger15
88
Arlington, Texas
Feb 14, 2006
  • Feb 14, 2006
That bushing was not supossed to be there in the first place. The DA previous owner left it stuck there.
Ok now to the problem I have always had. My clutch from engaged to disengaged is about 2 inches of foot movement. No matter how I adjust it; all it seems to do is move the place of initial engagement.
Here is a list of of clutch related parts: MM quadrant, cable, and Firewall adjuster. Clutch is a pretty new (2-3000 miles) Stage one Spec. I have a Jegs clutch fork, and a stock resurfaced flywheel.
big_tiger15
88
Arlington, Texas
Feb 14, 2006
#10
  • Feb 14, 2006
  • #10
could i be like that because the flywheel was resurfaced to thin?
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
