Clutch Pedal tick
  • Thread starter Thread starter No.11
  • Start date Start date Oct 19, 2010
No.11
614
10
48
Los Angeles
Oct 19, 2010
  • Oct 19, 2010
The other day I was driving to Halloween Horror Nights, so you know I was stuck in some very crappy, clutch-heavy traffic. So, after a while of this, I started getting this ticking from the clutch, somewhere maybe by the quadrant. not sure if i should be worried. the cable is a Maximum Motorsports performance clutch cable with about 100 miles on it.
Edit: the tick only occurs while letting go of the clutch, and only when I use the clutch heavily like in bad traffic.
TrophyHead
1,195
11
49
PA
Oct 19, 2010
  • Oct 19, 2010
Is the quadrant where the cable attaches to pedal....... plastic or metal? If plastic upgrade your quadrant.
No.11
614
10
48
Los Angeles
Oct 19, 2010
  • Oct 19, 2010
its metal. it came with the bbk clutch quadrant/cable/adjuster package. brand is gripp. would my cable getting frayed make a noise like that?
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Oct 19, 2010
  • Oct 19, 2010
This is weird, I have this same problem. In heavy traffic conditions where you are engaging and disengaging the clutch a lot you will hear and feel a click in the clutch pedal on the way up. I have an MM clutch quadrant and firewall adjuster, and a king cobra clutch. I have been through multiple clutch cables, I am on my third one since installing the king cobra clutch, not sure if it is related and not sure why it does this.
No.11
614
10
48
Los Angeles
Oct 20, 2010
  • Oct 20, 2010
when my last cable snapped, it did so only a few inches from the quadrant... probably around the area of the adjuster, so I wonder if the problem is around there. I better check to see if the cable is frayed which may be causing that noise.
TrophyHead
1,195
11
49
PA
Oct 20, 2010
  • Oct 20, 2010
I dont know if this will lead to anything but here goes.
I wonder if the BBK/Gripp quadrant is made for the heavier/thicker cable that came with the kit. The BBK cable is bigger than stock. The MM cable is stock size diameter cable. Maybe it's not riding on the quadrant groove the correct way. Just a thought.
No.11
614
10
48
Los Angeles
Oct 20, 2010
  • Oct 20, 2010
hmmm trophyhead you might be on to something. actually I took a look at the piece of snapped cable and it does look like the breakage was t the quadrant, not the firewall. I'll have to look into that with more time. thanks!
fiveohwblow
Official Member
2,169
145
155
Oct 20, 2010
  • Oct 20, 2010
I have a similar condition but mine is stock and happens when pressing it, not depressing. It is also when I am in heavy traffic. I attributed it to heavy clutching and heat curious to find out what it is.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
