  • 2005 - 2009 Specific Tech
Clutch Peddal Not Consistent
  • Thread starter Thread starter Exile918
  • Start date Start date Jan 8, 2018
E
Exile918
68
  • Jan 8, 2018
Been having this rather annoying issue and im wondering if this happens to all you 5 speed owners. Basically my clutch feels fine for the first few miles of a normal drive but eventually it feels as if the clutch engagement point either changes or its just not as consistent. After a good drive and stop and go traffic the clutch engagement becomes more of a pain. The clutch has about 10k miles on it and its never been abused. Feels more or less hydrolic related but cant pin point. Any help would be appreciated. Note Almost feels like the engament point moves further down the peddal travel. Ive bleed the car several times upgraded to steel braided line and changed brake fluid..
F. Jason Garriott
58
Huntington Beach CA, USA
Jan 19, 2018
  • Jan 19, 2018
There's air in the lines. Get a hand-vacuum pump from Harbor Freight, screw it to the top of the brake master and pump the pedal 100 times plus. The bleed valve, if it exists, is too hard to get to under the car. Good luck.
E
Exile918
68
  • Jan 19, 2018
I tried that and it helped a bit but eventually it felt the same unless I did it wrong. What are the steps to bleeding it with a pump?
Dino Dino Bambino
1,673
90
79
Cyprus
Jan 19, 2018
  • Jan 19, 2018
Agree that there's air in the hydraulic system but if this has only recently become an issue, the cause could be either a leaking clutch master or slave cylinder.
How does the brake pedal feel?
E
Exile918
68
  • Jan 19, 2018
My car was originally auto trans and i noticed that when i made it manual the breaks felt better. In other words before the brakes felt spongy but it went away when i made the car manual. However the clutch engagement was never consistent. The slave and clutch kit was brand new. I put on a used clutch master cylinder so im kinda leaning towards a bad cmc..
E
Exile918
68
  • Jan 19, 2018
E
Exile918
68
  • Jan 19, 2018
The clutch master cylinder is not leaking tho and im not losing any hydro fluid..
E
Exile918
68
  • Jan 19, 2018
And this has been an issue since day one in other words since we made the car manual. It shifts fine once ur going but clutch engagement from first is not consistent and after a good drive it feels like crap..
Dino Dino Bambino
1,673
90
79
Cyprus
Jan 19, 2018
  • Jan 19, 2018
Sounds like the only thing wrong is air trapped in the system. Good luck bleeding it 'cause it's a PITA.
E
Exile918
68
#10
  • Jan 22, 2018
  • #10
So update fellas! I bought a cmc cus i feel thats where my problem is however i havent installed it yet. What i did instead is took my pops advice and installed a seperate resevoir for the clutch fluid and wait to see if this cures. Capped the old nipped made bracket n everything came out really good! Clutch def feels a little better and bleeding wasnt hardly even necessary. Three bubbles at the most. Now im wondering if the problem im having is also throttle related.. Everyday i jump in my car it feels perfect for the first 20 minutes or so.. On long drives its a drag tho. The throttle also get extremely touchy after a while. Almost like it changes where i give it the same amount of gas to get going off of first gear but it lags and all of a sudden revs insane!! Engaging the clutch damb near impossible. I drive it hell smooth for the first 20 but then it feels like the gas peddal isnt consistent and the clutch feels like it has to ride a bit. I just cant pin point it all out for this damb car to be Consistent!!! Any thought?
Dino Dino Bambino
1,673
90
79
Cyprus
Jan 23, 2018
#11
  • Jan 23, 2018
  • #11
Faulty throttle position sensor.
E
Exile918
68
#12
  • Jan 23, 2018
  • #12
The strange thing is that my idle is pretty good.. Once it was a little bouncy but cleaning the throttle body fixed it! Is it possible for a throttle sensor to work just fine and after some time driving to just go out of wack and then sorta work? I have no check engine light or nothing..
Dino Dino Bambino
1,673
90
79
Cyprus
Jan 24, 2018
#13
  • Jan 24, 2018
  • #13
Yes it's possible for the TPS to begin malfunctioning once it becomes heat soaked.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Jan 24, 2018
#14
  • Jan 24, 2018
  • #14
It's odd that you provide all of this information:
but it takes some time to get to this:
lol
You need to go back and look over the entire install. Look at everything that you touched to make the conversion happen. Did you have to make any tuning changes to accommodate the swap to a manual?
You mentioned adding a reservoir. Does your installation now mirror what you would find on a stock manual car? If not, what's still different?
E
Exile918
68
#15
  • Jan 26, 2018
  • #15
I see what you mean. But no the stumbling idle and inconsistent throttle response has nothing to do with the drivetrain. Everything that was done for the swap was to spec down to the bolts and torques. Did it all under 1200$! It made clutch engagemnt alot more difficult for obvious reasons and thats the reason why ive overlooked the throttle body. I found a motorcraft tps for 33 bucks and ima give that a go. I was considering a new throttle body but bullitt95 is making sense!
E
Exile918
68
#16
  • Jan 26, 2018
  • #16
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
