clutch /preasure plate torque?
As DHearne pointed out more details would be helpful. If you are refering to the transmission to clutch/bellhousing bolts 37-42 ftlbs is recommended don't overdue it or else you well blow out the threads in the housing. Then you will be rethreading it with helicoil or replacing it. Good luck getting a torque wrench to be useful on the top 2 bolts though I remember having issues with this in the past. If you are refering to the clutch/bellhousing to engine bolts 40-50 foot lbs is recommended. :canada:
