Hi, I have a weird problem with my 98 cobra. I have a centerforce dual friction clutch with about 10,000 miles on it with steed adj cable, firewall adjst, and quadrant. I can crank the car put it in 1st ease out on the clutch to move the car, press the clutch back in and its a little hard to pull into neutral but then after its in neutral it will not go back into any gear untill I press back down on the clutch a time or 2. I have had it also to get stuck in reverse after I back out of my drive and then try and go to 1st, I have to cut the car off then it will slide right into first and then crank it and its ok. Anyone have a clue what this could be I have tried adjusting the firewall adjuster but it didn't seem to help, would transmission fluid have anything to do with this, HELP
