For the past few days, it seems that when i take off in 1st or back up that there is a really light vibration/rattle in the clutch pedal right at the very top of pedal travel. The clutch maybe has 3-4k miles on it. Its a King Cobra Clutch, aftermarket quadrant and firewall adjuster, ram pilot bearing, and a new TO bearing. The flywheel was also replace with one from ford racing. I pulled the inspection cover and nothing looks bad, tried to turn driveshaft by hand (recently did new gear install so i had to check if that was moving smooth). It doesn't do this in any other gears accept first and reverse. The only thing ive actually done recently was a new transmission mount (rubber) and a trickflow diff cover.
Any suggestions as to what this might be?
I searched clutch chatter but i guess that isnt what i have cause the symptoms were different.
Thanks,
David
Thanks,
David
