clutch problem
  • Thread starter Thread starter cjb
  • Start date Start date Feb 26, 2006
C
cjb
9
  • Feb 26, 2006
Hi all, first post. I recently picked up an '87 LX for cheap, but the clutch will not disengage. Before I go and replace it, I was looking for some other suggestions. The guy I bought it from said the clutch was replaced about a year and a half ago. After it sat for about two months, no worky. I pulled up on the pedal (it still has the stock quadrant), but the cable's as tight as it can be already. I checked the travel on the fork with the bellhousing cover removed, and it seems like it moves ok, and I can see the fingers on the pressure plate moving.
I don't really have a lot of extra time on my hands to change the clutch (I'm in Army flight school), so any suggestions on how I could get this thing in gear would be greatly apprecited.
Thanks in advance.
Chuck
HISSIN50
34
129
Feb 26, 2006
  • Feb 26, 2006
I find it hard to judge fork movement in terms of getting enough leverage to disengage the clutch.
Can you feel freeplay in the cable as you start to depress the pedal (I would think so if you are unable to disengage the clutch)?
The other possibility is that the cable stretched or the quad/pawl teeth are on the outs. One could try shimming the cable (for driveway diagnostics only!) - that is where I might start if I really didnt think the clutch itself was gone.
Good luck.
C
cjb
9
  • Feb 26, 2006
The quad/pawl teeth seem ok.
How do you suggest shimming the cable?
Thanks.
HISSIN50
34
129
Feb 26, 2006
  • Feb 26, 2006
The goober method (what I would do for a one push test) is to shim it at the fork, if you are able to.
The much better way is to shim it at the firewall (where the big rubber grommet is).
If you get under the car and find there is zero slack in the cable already, I wouldnt bother with the shimming.
When I have a clutch I wonder about, I shim the tar out of it so that it shouldnt even engage, and if it still wont disengage, I know there is a real good shot that the clutch itself is bad.
Just MHO.
Good luck Chuck.
C
cjb
9
  • Feb 26, 2006
There's no slack in the cable. Guess it's new clutch time for me.
Thanks Hissin50
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
