  • 1994 - 1995 Specific Tech
Clutch problem
  • Thread starter Thread starter sctops140
  • Start date Start date Jul 31, 2006
sctops140
  • Jul 31, 2006
I have a 94 GT. When my clutch pedal is out, my car is making more of a ticking sound rather than a squeaking sound. You push the clutch in about half way, and the sound goes away. You look underneath the car and you can see the clutch fork is vibrating I guess. You can put slight pressure on the clutch fork and the sound goes away. Does anybody know what the problem is? I've put a new throwout bearing, steel bearing retainer, and adjustable cable setup...and the problem still exists. The clutch was relatively new when I bought the car. Could it be the clutch fork? The car has a blower, if it's a heavy duty clutch, could it be too much for the stock clutch fork? Help?? Anyone?? Much appreciated. --Sean
bill302
2,131
alabama,gadsden
Jul 31, 2006
  • Jul 31, 2006
inproper cable adjustment is your problem...does the clutch fork vibrate when the clutch pedal is not engaged? if so this would mean the cable is adjusted too tight the throwout bearing is contacting the fingers of the clutch and should not be no contact should be made until clutch is depressed.....
sctops140
  • Aug 1, 2006
When I adjust the clutch so it's just off the fingers, it doesn't release enough to put the car in gear (clutch drags) And it's impossible to shift, that's why I thought the fork may need to be replaced. I've messed with adjusting it with lousy results. Any ideas? Thanks
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
