  • SN95 4.6L Mustang Tech
clutch problem
  • Thread starter Thread starter bump14
  • Start date Start date Nov 7, 2010
bump14
  • Nov 7, 2010
Just bought a 2001 GT. Was in a collision and sat for a while. I got the car cheap when i picked it up just drove it right on the trailor. Has adjustable clutch cable, stage 3 clutch, Was gonna drive it down the street b4 i tore it down and cannot get it in gear. Grinds in 1st every single time and will not go in any other gear. Ive adjusted clutch cable all over the place but doesnt help. Only way you can get it in gear is to shut the car off and put it in gear. clutch, throwout bearing?? Whats the problem and what all should i try?
Thanks
Rick 91GT
Mustang Master
95
99
PA
Nov 7, 2010
  • Nov 7, 2010
If it has a aftermarket shifter the stops could be adjusted wrong or a little tight. It really just sounds like it is out of adjustment....
Check to see if the car has a aftermarket clutch quadrant in it, if so put the cable on the hook closest to the driver. Then go underneath and adjust the cable so it just puts tension on the fork. If you push inside you should feel it release about the height of the brake pedal, if is goes further towards the floor turn the nut in further on the cable underneath the car. If the clutch disengages at the top of the pedal the cable is too tight and you need to loosed the nut...
Check the fluid level also....
bump14
  • Nov 7, 2010
Got the mgw short throw shifter, adjustable cable and spec stage 3 clutch. Believe thats all it has. Noticed a little fluid leak.
bump14
  • Nov 7, 2010
and it doesnt have an aftermarket quadrant, so can i still try adjusting it at the quadrant or is there something else i should try?
Rick 91GT
Mustang Master
95
99
PA
Nov 7, 2010
  • Nov 7, 2010
The stock quadrant is not adjustable, check the fluid level first then back the adjustable stopd out on the shifter and back the cable way out and start over with adjustment.
bump14
  • Nov 7, 2010
I put my foot under the clutch. i picked it up as far as i could towar the driver seat. Started it up and goes in and out of every gear perfect. should i still be worried or just drive it?
Rick 91GT
Mustang Master
95
99
PA
Nov 8, 2010
  • Nov 8, 2010
That is how you reseat the stocker....never had one that far out however. Where does the clutch engage and disengage at, about brake pedal height? If so drive it or adjust it a little to your liking with the cable...
bump14
  • Nov 9, 2010
guess i spoke to soon. i had the driveshaft out when i got it shifting good. Put driveshaft back in and it wont shift now. with the clutch on the floor u can try to ease it into gear and the wheels start spinning. That is with my foot on the floor. Any ideas of what i should do?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
