  • 1994 - 1995 Specific Tech
clutch problems please help
  • Thread starter Thread starter a_k
  • Start date Start date May 25, 2006
a_k
170
Saratoga NY
May 25, 2006
  • May 25, 2006
I ordered a centerforce dual friction clutch and I just put it on and bolted my trans back on (this is all outside the car) I got the transmission rebuilt and I have a new ford oem throwout bearing on there. I was guessing I got sent the wrong pressure plate because I had to use a 5/16 drill bill on the pressure plate holes in order to fit the bolts through to the flywheel. (spec flywheel) Whenever I push in the pedal now, really close to the floor it makes a nasty creak noise. It doesn't do it when you engage it though. It sounds like the throwout bearing is binding up almost on the fingers. If you push down very slowly it won't make the noise. What a pain in the ass lol looks like ill be taking it all out again, I just bolted up the longtubes too This is my guess but I wanted to check with you guys first If you could help me out I would really appreciate it.
HISSIN50
34
129
May 25, 2006
  • May 25, 2006
I would make super sure that the pedal, cable and fork are not the issue before tearing things totally back apart. Having the car safely in the air with an assistant pushing the pedal (slow and fast) while listening might be wise.
Good luck.
a_k
170
Saratoga NY
May 26, 2006
  • May 26, 2006
yeah I did that and when you look up from under it seems like its coming from around the throwout bearing. Is it normal to have to drill the pressure plate out? THanks for the help
ceaserthethird
33
  • May 26, 2006
I just finish installing my ,Rear main seal , pilot Bearing , Fidanza Aluminum Fly. , King Cobra Clutch , ..........What A HUGE pain in the Ass it turn out to be ....
i had to Grind the hole's on the pressure plate Also ....
It's find though ....
HISSIN50
34
129
May 26, 2006
  • May 26, 2006
I've never had to drill a PP, so I cant comment. WHile that doesnt sound right, I wouldnt be surprised if this is kinda common
Do you have the cable setting pretty loose (or does the clutch engage right at the top of the pedal depression)?
I'm sorry to be stuck on the cable thing, but I wanted to make sure that's not it (I've had a couple cars that do just what you describe, including my 88 GT vert) and was the cable and linkage - not the actual clutch. That said, if you got the wrong PP, all bets are off.
Good luck.
a_k
170
Saratoga NY
May 26, 2006
  • May 26, 2006
Well you can adjust the cable with the firewall adjuster to the point where it doesn't do it. The only thing with that is
it gets pretty loose and the top half of the pedal is very light and spongy feeling. I'm not sure how the dual frictions feel but I am asumming this is not normal. I also don't think I could fully disengage the clutch with it set this loose. I talked to the place that rebuilt my trans and he basically told me to drive it and not worry about it and if it still does it swing it by and they will take a look at it. I guess I just want to get a second opinion on that before I keep putting my car back together. I was also wondering if one of the small weights on the pressure plate could cause this to happen, I wouldn't think so though.
HISSIN50
34
129
May 26, 2006
  • May 26, 2006
WIth that last bit of info, it does almost sound like the PP fingers are overextending. But I have NOT used that clutch (but friends have it, and dont have any clicking like that) - I just posted to say that I saw your post, I dont know, and good luck with figuring it out.
I also would not want to drive with so much slack in the cable - that eats TOB's and input shaft retainers.
Good luck.
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain Vibration after changing clutch
  • keel
  • Oct 18, 2024
Fox 5.0 Mustang Tech Nov 8, 2024
NEED SOME SPEC CLUTCH DIMENSIONS
  • PonyGTrider
  • Jun 2, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2024
PonyGTrider
