Clutch problems?
89GTBLKonBLK
24
I was driving today when all of a sudden my car started going up and down(rpm's). It felt like the car was almost stalling out but it would have been impossible in 2nd, 3rd ect.. gear. Do I need to adjust the clutch or does it look like I might need a new one?
it was driving as if i was slightly pushing the gas pedal over and over rpm would jump from 2k to 2.5k and always down up down up rpm wise, the car would continue to accelerate but roughly almost like it wasnt getting gas then it would then it wouldnt if that makes sense. I didnt drive it for long for fear that I would damage something else. hope that helps. Car would Idle fine at rest so maybe slipping from the clutch?
I would pull the codes and read through Jrichker's idle surge sticky (It's inside one of the sticky folders at the top of the forum).
Good luck.
89GTBLKonBLK said:
I figured out that the clutch must be slipping because the car is quite sluggish. What should I do about this?
I had a simular problem....the clutch was in good shape but the cable was getting caught where it passed through the firewall. I was only getting partial pressure.
I bought a BBK adjustable clutch quadrant and fixed it in no time.
Is it normal to have to put the clutch to the floor board for it to start, Im talking like completely down to the floor. Is it possible the cable is wearing out and that is why it dosnt fully engage? I can smell clutch after driving and getting out of the car also? If so is this an easy job or one more easily done by a mechanic?
It can be normal, but it has nothing to do with your clutch. There's a switch (clutch safety switch) on the arm of the clutch pedal. When the button on the switch is pressed in, it allows the car to start. You can adjust the switch, but the first time you jamb the clutch to the floor (spirited driving), it will reset and you'll be pushing the pedal to the floor to start the car. Been there and done that. No T-shirt though.
Good luck.
89GTBLKonBLK said:
what about the sluggish driving? Should I take it to the tranny shop or is there a way to adjust the clutch cable? I havent done much with 5spds just chevy auto's.
You described surging (at least that's how I interpreted the up and down part). I dont see where this has anything to do with the clutch.
A slipping clutch would have the motor run like a top but act like a world class 100 meter sprinter trying to run a best time on ice - his motion is flawless but he simply cant apply all that fluid power in an efficient means to the ground.
You would note that when you mash the gas from low RPM (often in 3rd and 4th - dont use 5th) the motor revs up but the car doesnt take off (kinda like if you ever accidentally started off from a stop in 3rd gear - you have to keep slipping the clutch to keep from stalling).
Good luck.
that sounds more accurate, but the reason I said clutch is because of the smell but I could be wrong, I will check out the surging writeup. I also notice 8/10 times when I let out the clutch a small popping sound, like a hammer tapping sheet metal happens just below the emergency brake. Maybe just be nothing.
