  • SN95 4.6L Mustang Tech
Clutch Problems?
  • Thread starter Thread starter bullitt 5561
  • Start date Start date Nov 2, 2006
bullitt 5561
75
  • Nov 2, 2006
When I am at idle, I can hear a whine. When I depress the clutch, the whine/whurr goes away. Let up on the clutch... whine comes back. Is this a sign of my clutch going bad. Could this be related to this thread also?
http://forums.stangnet.com/showthread.php?t=669350
Rickyll7
718
  • Nov 2, 2006
sounds like your throwout bearing is bad
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 3, 2006
  • Nov 3, 2006
TOB
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Nov 3, 2006
  • Nov 3, 2006
Yep, its your tob. Mine does it too, gets real annoying.
bullitt 5561
75
  • Nov 3, 2006
ok doc how long does she have and how much to repalce?
Rickyll7
718
  • Nov 3, 2006
you probably have 3-4 months of easy driving at a pace of about 12k miles per year. thats how long mine lasted after beginning to squeal. you can replace it yourself for like 20 bucks or something, a shop MIGHT charge like 200-300 for labor, I am not sure about that. I like to do my own work. Dropping midpipe, driveshaft, and tranny = easy with the right tools. Just need to break those bolts loose with a breaker bar. you will also need a set of extensions and swivels/u-joints(whatever those things are called) a transmission jack with some tie-down straps helps a lot. good luck!
bakos24
87
134
NE, OH
Nov 3, 2006
  • Nov 3, 2006
I been going with mine for about 4-5 months. I dont think it will do any damage. To replace it you have to drop the tranny. So depending if you can to it yourself it will cost you $10-15 for a new TOB, if you have to have someone esle do it will be close to $500-600 depening on the labor.
Rickyll7
718
  • Nov 3, 2006
someone really needs to make a good tob for our cars.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
