Clutch Problems
LightningWhite
15
To begin with a drive a 91 Mustang GT. When I bought the car it never shifted smoothly. I would always either have to force it into gear when shifting from another (1 to 2) or I could give it a second or two and it would shift just fine like it should to begin with. I thought I could solve the problem by adjusting the clutch. So this afternoon I tried the auto adjustment on the clutch, where you pull up until it clicks then push the clutch all the way in. Now after I've done that I have to force the car into gear when driving. It is hard to get the car into 1st and the majority of the time it grinds a little when going to 5th. Any idea as to what is the problem??? I kind of need to know because this is my only ride.
Is the point of engagement right above the floor? Have you checked for cable freeplay?
In any case, you very well might want to get an aftermarket quad and FWA before the stock quad/pawl breaks or loses its ability to hold its setting.
Good luck.
