  • SN95 4.6L Mustang Tech
clutch problems
  • Thread starter Thread starter blaxican27
  • Start date Start date Jul 17, 2009
blaxican27
39
Dallas, Texas
Jul 17, 2009
  • Jul 17, 2009
i have a 2000 gt with a king cobra clutch. ever since i have had the car (2 yrs) the clutch has always been extremely stiff. even after the install of the king cobra its still hard. Well back in january my clutch cable snapped so i had it replaced. the car came with a 2 fork steeda quadrant and firewall adjuster and the place i took it to took out my firewall adjuster and quadrant and replaced it with a regular quadrant and a steeda adjustable cable, well it still remained stiff and in april it snapped again. well i had the cable replaced once again and put back in my 2 fork quadrant. i am starting to have the same problem i did back before it broke in april which is that when i put the clutch in, the clutch does not release all the way and so i have trouble shifting in and out of gears, especially first and reverse. any suggestions as to what my problem could be. also i am thinking of replacing my clutch and cable once again and am wondering which is a better set up to go with.
Thanks guys....
C
cooter_11
138
GA
Jul 18, 2009
  • Jul 18, 2009
Sounds to me like your cable is binding somewhere. Make sure it is routed correctly and check your clutch release fork and make sure it is moving freely. Something might be streching it out and causing it to snap as well. Just check for anything that looks out of place.
You might just need to lube the throwout bearing, but that involves removing the tranny. If you plan on replacing it anyway, make sure you lube the part where the throwout bearing slides near the input shaft.
blaxican27
39
Dallas, Texas
Jul 20, 2009
  • Jul 20, 2009
thx for the info...i ended up taking out my steeda adjustable cable and installed a factory OEM cable, left my two 2 fork quadrant in and added back the firewall adjuster and thats seems to have done the trip...its shifting smoothly and the pedal is as soft as it should have been all along...only problem now is that my clutch pedal is up really high...i would liek to lower it just afraid of adjusting the cable since its working great right now...
joshjwc9
1,095
17
39
Palm Harbor, FL
Jul 20, 2009
  • Jul 20, 2009
Steeda and MM I think both sell a pedal height adjuster that evens the pedal with the brake pedal.
Maximum Motorsports :: The Leader In Mustang Performance Suspension has one for $20
blaxican27
39
Dallas, Texas
Jul 20, 2009
  • Jul 20, 2009
sweet....how difficult is it to install that adjuster....i assume with installing the adjuster i will need to adjust the firewall adjust once again is that correct? would i need to also to pull more slack on the cable from the tranny...
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
