Clutch Quadrant?
  • Thread starter Thread starter GreatWhite
  • Start date Start date Aug 18, 2006
1 of 2 Next Last
GreatWhite
232
Fairfield, PA
Aug 18, 2006
  • Aug 18, 2006
I have a Heavy Duty FRPP clutch in my car and my 2nd gear synchro sounds like it's starting to go bad (grinds on a hard shift when cold sometimes)... would a quadrant be a good upgrade to do? I plan on adding more power in the future and my clutch cable is still pretty new.
Thoughts?
-- cj
GearHd6
459
Ashford, CT
Aug 18, 2006
  • Aug 18, 2006
A quadrant is always a good idea but it may not fix your grinding problem. Wheres your clutch letting out? If its not letting out way at the bottom near the floor then the quad isnt going to fix it. Sounds like a worn syncro ring to me.
HISSIN50
34
129
Aug 18, 2006
  • Aug 18, 2006
I agree regarding the shifting issue.
That said, my HD PP requires a decent amount of pedal effort - I would swap the quadrant as this pedal effort might take out the stock quadrant.
Good luck.
GreatWhite
232
Fairfield, PA
Aug 18, 2006
  • Aug 18, 2006
Yeah, I know the gear problem is in the tranny. I bought it used when I swapped it out to the T5. I'm not too worried about that I guess, just figured a better quadrant would help it with not wearing on it any further.
The Heavy Duty FRPP clutch does require a good bit of effort, that's true. I like that feel though. You're right about the heavy pedal and the stock plastic quadrant, I could see it goin' on me one of these days. I might need to add that to my to-do list here in the coming weeks.
Any thoughts on which way to go as far as quadrants?
HISSIN50
34
129
Aug 18, 2006
  • Aug 18, 2006
I run a UPR Single hook quad, UPR extreme FWA and stock cable.
Were I buying again, I'd use the Fiore quad and FWA.
Good luck.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 19, 2006
  • Aug 19, 2006
My second gear grinds alot too, mostly on hard down shifts, or when I shift and dont push the clutch in hard enough without realising it, I have a brand new king cobra clutch, MM quadrant and fwa, like said before it may make i better because of pedal force, but its not going to fix
Id go with a fiore, but my MM does just fine.
If you need a new clutch cable get this one, its OEM non adjustable, its the one I use and wont be a pain in the ass adjusting.
http://www.buyfordracing.com/shop/product_info.php?products_id=374
GreatWhite
232
Fairfield, PA
Aug 19, 2006
  • Aug 19, 2006
Yeah my cable is new so I'm not worried about that. Do you really need the FWA adjuster?
Henceforward
The Avatar Master
485
  • Aug 19, 2006
I like my Steeda Double hook quadrant, and firewall adjuster.
310stanger
170
  • Aug 19, 2006
i use the billet summit quadrant and cable and have no problems at all
GreatWhite
232
Fairfield, PA
Aug 19, 2006
#10
  • Aug 19, 2006
  • #10
The Fiore quad is only around 30 bucks through Blue Oval, might have to pick that up.
HISSIN50
34
129
Aug 19, 2006
#11
  • Aug 19, 2006
  • #11
How else are you going to adjust the clutch?
GreatWhite
232
Fairfield, PA
Aug 19, 2006
#12
  • Aug 19, 2006
  • #12
I like it how it is? haha
HISSIN50
34
129
Aug 19, 2006
#13
  • Aug 19, 2006
  • #13
When you change quadrants, the adjustment wont likely stay the same. Pony up and spend the money on the FWA. You can get off brand stuff for super cheap (I've seen em go for under 10 bucks on ebay).
Good luck.
GreatWhite
232
Fairfield, PA
Aug 19, 2006
#14
  • Aug 19, 2006
  • #14
I think I'm going to go for the Fiore quad and it says it requires their FWA. So I'd need to get that one I'd assume? That adjuster is really nice it seems.
HISSIN50
34
129
Aug 19, 2006
#15
  • Aug 19, 2006
  • #15
I dont see why the Fiore FWA would be required for use with the Fiore quadrant, but if I could only choose one Fiore component, I'd want the FWA anyhow.
Good luck.
smokin joe
746
45
49
Dallas,TX
Aug 20, 2006
#16
  • Aug 20, 2006
  • #16
Have you tried to put your foot under the clutch pedal, pull up, and push down? I have a STEEDA quad, cable, and fwa and I hate it.
cliff88145
87
Sep 14, 2006
#17
  • Sep 14, 2006
  • #17
why do you hate the STEEDA?
K
Kerpal
400
#18
  • Sep 14, 2006
  • #18
How do you like your UPR firewall adjuster, Hissin? I bought one a while back but still need to pick up a quadrant before I put it in. Now I wonder if I should have just spent the money for a Fiore or MM adjuster.
I'm thinking MM for the quadrant... seems like they put a lot of thought into their design. Unless there's anything better out there now?
V
v8only
2,378
22
49
Sep 14, 2006
#19
  • Sep 14, 2006
  • #19
oh man, the fiore fwa is badass. So much better than the rest. It's got a sleave on the inside that rotates with the cable so the cable doesn't bind when you try to adjust. NO MORE skinning your fingers from a damn fwa that's seized. My sat for months without me turning it, and I came and was able to turn it with one finger.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Sep 14, 2006
#20
  • Sep 14, 2006
  • #20
yep, i love my fiore fwa and quadrant. i used to have a upr quadrant and fwa and i cant say how much better the fiore stuff is. there are no set screws with the fwa, it clicks and locks in at 1/4 turn increments. absolutely no problems and i will never buy another brand. thanks to jeremy
1 of 2 Next Last
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
