Clutch Question for the Experts
damacman
529
Phoenix, AZ
About three months ago, before the blower, a noise began to come from under the car when I was looking for a parking spot. The noise was present only at the bottom of whichever gear I was in - almost lugging the motor, but not quite. This has gotten progressively worse over time with the noise getting louder and present at idle to about 1,200 RPM with the vehicle out of gear, but the clutch fully released. Applying slight pressure to the clutch pedal would stop it.
Today, I popped it up and removed the inspection cover. The noise is being made by the release fork smacking the cover. All that I see appears in good condition - was thinking that a finger on the pressure plate was making the noise . . . I moved the inspection cover slightly so that the release fork wouldn't smack it, and the noise is gone. However, the release fork moves ALOT! How much should this move? Mine moves like 3/4" inch each direction at idle with the clutch out and the vehicle in neutral. Is this normal or is this a sign of a worn part? It moves enough that it actually shakes the car at about 1k RPM . . .
Yeah sounds like the fork has either slid off the pivot ball or one or both are broken... try pulling the fork out from the tranny then smacking it back inwards... that might help it set... man I remember that thing being a bitch to get on there.
damacman posted in another topic but never posted the results in his topic.
he had his pivot ball break off. the pivot ball wearing down is common but not breaking off. most of the time you will see grooves in it.
everytime you do a clutch you should at least check the fork and pivot ball. personally i would not do a clutch without replacing them.
I REALLY appreciate your input on this subject, SVTTECH76 - I saw your post elsewhere and it prompted us to also order, along with a much needed new clutch kit and flywheel, a pivot ball and clutch fork. I don't want to have to drop the trannie again for a long time. (And thanks to Randy for handling the order!)
Hunter-White said:
When I get on the car just a lil bit, it will start to give a vibration in the pedal and it will just get worse and worse if I keep getting on it. Also there is a rattling sounding noise when the car is at idle. Could that be my prob?
how far from the floor does the clutch start to engage ( car start to move) spec is no less than 1 inch.
Your clutch cable could be out of adjustment. Do you have a aftermarket quad and adjuster. if you do try tightening the cable. if not pull up on the pedal, if that don;t work then get a aftermarket quad/adjuster.
