  • 1994 - 1995 Specific Tech
Clutch Question
  • Thread starter Thread starter YELLOW 94
  • Start date Start date Feb 21, 2007
Y
YELLOW 94
428
Rio Rancho NM
Feb 21, 2007
  • Feb 21, 2007
I have a 94 GT 5 speed and need a new cluthch kit. Im not sure if I need the 10 or 26 spline.
Also I want a centerforce so if anyone has the part number for the kit let me know.
later
Orlie
divit250r
314
Columbia City, IN
Feb 21, 2007
  • Feb 21, 2007
You should need the 10 spline, that's stock T5 input shaft spline count. Not sure on the part number, I bought my dual friction CF used.
Scott
Wi Stang
248
Fountain City, WI
Feb 21, 2007
  • Feb 21, 2007
I don't see a different transmission listed in your sig, so I assume you are still running the stock T-5.
I got these part numbers for the clutch disk and pressure plate kit from the Centerforce website.
DF021057 - is that part number for a Dual Friction Clutch kit
01920830 - is the part number for the DFX clutch kit.
I'm not too sure what the capacity difference between the two clutches are though.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 21, 2007
  • Feb 21, 2007
The 94/95 pressure plates have more clamping power under Centerforce.
A simple check of their website will give you the part numbers
10 spline is what you need, good luck, you are getting a good clutch!
Cobra4075
286
Tinley Park, IL
Feb 21, 2007
  • Feb 21, 2007
Are you still running the stock T-5? With those numbers, that trans is a time bomb should you hook. If you upgrade to a TKO you will need a 26 spline clutch.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
