  • SN95 4.6L Mustang Tech
Clutch Sensor?
  • Thread starter Thread starter bakos24
  • Start date Start date Jun 17, 2006
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Jun 17, 2006
  • Jun 17, 2006
Ok, so last night me and my gf go to Dairy Queen, ate some ice cream and went to go leave. My car did not start . all power worked but it just would not start at all. I had to pop the clutch to get it started. I tried starting it a few times after and started right up. . Today I get ready to go to work and try and start it and it does the same thing, will not start. Well my Uncle said that there might be a sensor for when the clutch engages that makes it start and that it might be broke or need adjusted. Anyone know about this? or have any other ideas why it wont start. Thanks guys.
RandyStinchcomb
1,159
Randallstown, Md
Jun 17, 2006
  • Jun 17, 2006
ther is a clutch starter switch under the dash on the clutch pedal asbly, I've never seen one go bad, but anything is possible. I would look to other sources first before replacing it. when you say "no start" did the engine crank over, make clicking nosies or what?
bakos24
87
134
NE, OH
Jun 17, 2006
  • Jun 17, 2006
It did not do anything. It kind of made a slight click, but it was not that loud or noticable, seemed like it faded away, that only happenes when I first try and start it. All the lights and everything came on and that was it. Any ideas?
RandyStinchcomb
1,159
Randallstown, Md
Jun 17, 2006
  • Jun 17, 2006
hows the battery and batt cables?
bakos24
87
134
NE, OH
Jun 17, 2006
  • Jun 17, 2006
Those should be good. I just had the battery replaced a few months ago.
RandyStinchcomb
1,159
Randallstown, Md
Jun 17, 2006
  • Jun 17, 2006
check to make sure the cable ends are tight on the battery termials then, if they check-out, get the battery tested anyway.
bakos24
87
134
NE, OH
Jun 17, 2006
  • Jun 17, 2006
Cool, thanks I will do that. Any other itdeas in case that checks out ok. How about the starter, could that be going bad?
RandyStinchcomb
1,159
Randallstown, Md
Jun 17, 2006
  • Jun 17, 2006
doubtfull, as the starters on these cars are pretty "bullittproof" as are the alt
bakos24
87
134
NE, OH
Jun 17, 2006
  • Jun 17, 2006
well, I tested my batt and it tested good. Any other ideas?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
