Clutch Vibration from Turning Steering Wheel??
hmmm....sounds like an odd prob. one thing that may help is to just check the routing on the clutch cable. make the the bracket on the firewall is not loose. that could be vibrating. hope u figure it out.
Another idea ... your steering column bolts directly to your pedal assembly -- maybe a couple bots have worked a little loose? They are the four big ones if you look under the dash -- not hard to get to.
