  • SN95 4.6L Mustang Tech
Clutch warning signals?
  • Thread starter Thread starter menasci
  • Start date Start date Feb 2, 2004
menasci
640
Chandler, AZ
Feb 2, 2004
  • Feb 2, 2004
What are the initial warning signals that would indicate that you're in need of a new clutch?
Does slippage feel like the car goes and then lags and then goes again?
or...
Does the car just feel sluggish?
JonJon
4,801
back in Marylands
Feb 2, 2004
  • Feb 2, 2004
If you floor it, your RPMs rise but your speed doesn't (Clutch is spinning and you don't move)
menasci
640
Chandler, AZ
Feb 2, 2004
  • Feb 2, 2004
So is it all or nothing? In other words...
Good clutch = you move
Bad clutch = you don't move
and NOT......
Bad clutch = You move, but not as much as with a good clutch (Slower accellertion)
menasci
640
Chandler, AZ
Feb 2, 2004
  • Feb 2, 2004
and NOT......
I did a little research and I've got it now.
"Slipping occurs when the driven disc fails to rotate at the same speed as the driving members when the clutch is fully engaged. This condition results whenever the clutch pressure plate fails to hold the disc tight against the face of the flywheel. If clutch slippage is severe, the engine speed will rise rapidly on acceleration, while the vehicle gradually increases in speed. Slight but continuous slippage may go unnoticed until the clutch facings are ruined by excessive temperature caused by friction."
stang09er
115
Clarkston, MI
Feb 2, 2004
  • Feb 2, 2004
Thanks a lot for clearing that up...i think i need a new clutch
im pushing 90,000 miles on my car and it doesn't seem to slip at all, but the engine revs don't match the actuall acceleration of the car. does anyone recommend a particular brand/model over another.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
