clutch
  • Thread starter Thread starter LithiumX
  • Start date Start date Aug 23, 2006
LithiumX
  • Aug 23, 2006
hey everybody
listen...i dont know if its just my car or all mustangs.....but my clutch is really really hard to push and it is long and catches all the way at the top....as soon as i put my foot on the clutch and push a little its already disengaging....
first i want to know if they are all like that...
second...could i make my clutch shorter...by...say...making the clutch cable shorter...i kinda already know this but is there a way to make it easier to push...
also...how much would it be to change the system to a hydraulic one..
and finally...how much is it to replace a clutch plate...cuz i think mine is worn...and could i do it myself...how much would it be if i did it myself and if i would get a mechanic to do it.
thanks
MustangLX-5.0
856
Lehigh Acres Fla.
Sep 10, 2006
  • Sep 10, 2006
You might want to try posting this one over in the V6 Technical Discussion section.
Has your clutch always been like this or just recently? Some clutches are normally a bit difficult to push but usually only the high performance types are like that or the heavy duty clutches on large trucks.
How many miles does your car have? If your clutch components are worn then a shop can charge anywhere in the lines from $200 - $400 for a new clutch.If you don't have any prior experience then I wouldn't reccomend taking the task on yourself.Unless you have help from an experienced DIY'er.Clutch replacement requires the removal of the transmission besides any other object interfering with removal (starter,exhaust pipes,driveshaft,etc)
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
