  • SN95 4.6L Mustang Tech
clutch?
  • Thread starter Thread starter duzy
  • Start date Start date Nov 6, 2011
duzy
80
jacksonville fl
Nov 6, 2011
  • Nov 6, 2011
03 mustang gt. when i start to drive i feel vibrations cant remember at the time if i can feel it in the pedall, but also if i put it in 5th gear and going slower than i should i feel a lot of vibrations want some input i feel as if its the clutch slipping its happened every now and then but i has been doing it really bad now let me know.
trinity_gt
3,125
81
99
Canada
Nov 6, 2011
  • Nov 6, 2011
Sounds like two different issues.
The first sounds a bit like clutch "chatter" and occurs when the clutch is taking up (i.e. you're still releasing the pedal) from a stop. It can happen if the clutch has been overheated and the disc faces are glazed, if the flywheel or pressure plate has heat checks, if the lining gets contaminated with oil etc. Sometimes chatter can occur on aftermarket "racing clutches", especially puck type discs, discs without sprung hubs or without marcel springs etc. Depending on the cause, sometimes the condition goes away on its own if the clutch is not abused for a while (e.g. faces are glazed) or if its a racing clutch, you'll have to get used to it.
The second sounds like typical "lugging" behavior. You say you're in top gear "going slower than i should"; I suggest selecting a lower gear to alleviate driveability issues seen when lugging.
duzy
80
jacksonville fl
Nov 6, 2011
  • Nov 6, 2011
ok so what should be done?
duzy
80
jacksonville fl
Nov 6, 2011
  • Nov 6, 2011
its a stock clutch it does this shaking in every gear until i hit a certain rpm usually around the same rpm
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Nov 6, 2011
  • Nov 6, 2011
Try re-describing the issue:
Do you get a vibration only when you're on the gas?
Do you get a vibration when you're at cruise and the gas is leveled off?
Do you get vibration when you're in gear and coasting?
Do you get vibration at speed with the car out of gear?
Is the vibration speed dependent or RPM dependent?
Do you feel the vibration is the shifter or clutch pedal?
How many miles on the clutch?
duzy
80
jacksonville fl
Nov 8, 2011
  • Nov 8, 2011
vibration when im on the gas. when i start of in first gear the car will bog out and ill have to sometimes give it more gas and the more gas i give it the worse it shakes only sometimes though. not sure how many miles on clutch. it did it sometimes when i first got the car only in 5th gear and very slightly but now its bad. not sure if shaking is in the handle or clutch.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
