  • 1994 - 1995 Specific Tech
cobra brake upgrade
  • Thread starter Thread starter 1smoothmustang
  • Start date Start date Jun 1, 2006
1smoothmustang
11
  • Jun 1, 2006
need some quick advice.i have a 95 gt with a cobra front brake upgrade.the brakes feel a little soft at times and my mechanic told me that they should have changed the master cylinder out to a cobra cylinder to give off the extra pressure needed for the upgrade. does anyone know if this is true or not? also i need to upgrade the fuel pump. the car is putting out about 325 hp and im putting on a 100 shot of nitrous.should i go with the 255 walbro or 190 ? they are the same price. can a 255 be overkill for the car or good for future upgrades?thanks guys
95strokerPSU
986
Sacramento from Philly
Jun 1, 2006
  • Jun 1, 2006
Your mechanic is right about the master cylinder, although I don't know of anyone who has actually done. I would try bleeding the brakes real good and if that doesn't give you the pedal feel you want then try the cobra master cylinder.
As far as the fuel pump go with the walbro 255 high pressure. I don't think you can go overkill on the pump, it's more based on the injector.
mootang
907
texas
Jun 1, 2006
  • Jun 1, 2006
255lph you'll probably need it later anyways!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 1, 2006
  • Jun 1, 2006
hmm.. when i upgraded to cobra brakes on my 02 the pedal actually felt a bit stiffer
maybe they need to bleed the lines a bit more
91LX_5L
1,943
British Columbia
Jun 1, 2006
  • Jun 1, 2006
Actually im pretty sure the Cobra MC will make the pedal feel 'lighter' the stock GT MC makes it really stiff. I know mine with my GT MC and Cobra Brakes they are super stiff and really nice, like 1/2" down and its breaking good.
scarless
175
  • Jun 1, 2006
Going to a Cobra MC will make the peddle softer. A problem with the GT MC is that it's larger than the Cobra and the peddle can feel rock hard. Power bleed the system before you do any swaps.
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jun 1, 2006
  • Jun 1, 2006
Stainless steel brake lines will stiffen the brake pedal feel. I did this with my Cobra brake upgrade (kept stock MC) and the pedal feel is perfect. The pedal feel is stiffer than stock but by no means is it too stiff.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 2, 2006
  • Jun 2, 2006
this is correct. my recommendation would also be to bleed the brakes again.
1smoothmustang
11
  • Jun 2, 2006
thanks
peddle started off pretty firm but didnt actually stop the car good.figured with the upgrade it should stop on a dime?got the cobra mc and install for 150 dollars so im dropping it off today for the install.will let u know how it turns out.also went with the 255 fuel pump. thanks for the info, just wanted to make surte the mechanic wasnt jerking me on the mc.
94-302-vert
1,947
NE CT
Jun 2, 2006
#10
  • Jun 2, 2006
  • #10
Yeah we went around my car like 4 or 5 times bleeding and kept getting air out of the fronts... they front cobra calipers are a PITA to bleed...
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 2, 2006
#11
  • Jun 2, 2006
  • #11
no matter what you have done to the car, i would always go with a 255lph pump. it is big enough to support quite a bit of hp and being that the mustang has a fuel system with a return, if you are under utilizing the pump, all the unused gas gets sent right back to the gas tank.
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:17 AM
keel
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
