Cobra brake writeup
  • Thread starter Thread starter Engel
  • Start date Start date Jul 23, 2007
Engel
219
Currently Fort Walton Beach
Jul 23, 2007
  • Jul 23, 2007
hi all, I was wondering if there was a cobra brake install on a sn95 write up somewhere..
also does the axle have to be pulled to get the rears in? seems like more of a pita then i bargained for
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jul 23, 2007
  • Jul 23, 2007
I am 99% sure you have to take the axles out.
Yobi1Kanobi
559
  • Jul 23, 2007
why would you have to pull out the axle?
The Green GT
1,269
Louisiana
Jul 23, 2007
  • Jul 23, 2007
To get to the brackets.
Yobi1Kanobi
559
  • Jul 23, 2007
okay good to know one less thing i will bother with
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 23, 2007
  • Jul 23, 2007
If you're doing the rears, the axle does need to come out in order to mount the rear brackets. The fronts are very easy to swap though. Taking my time, I had them done in like an hour and a half. The reason I didn't get the rears yet was because of the axle needing to come out. I'll wait until I do new bearings/seals/diff/gears/31 spline axles for those.
The Green GT
1,269
Louisiana
Jul 23, 2007
  • Jul 23, 2007
Im just going to get the kit that puts bigger rotors on the stock brakes when I get my new brakes.
1TallMF
955
Montreal
Jul 23, 2007
  • Jul 23, 2007
I don't have a write-up for the front, but its really quite simple to do.
Remove the stock front brakes by first disconnecting the brake line fitting at the flex line by the inner fender, and removing the bolt for the retaining bracket. Next, instead of wasting your time with the torx bolts that hold the caliper to the bracket, just remove the entire caliper/bracket assembly by removing the two 15mm head bolts on the steering knuckle. With these out, you should be able to remove the caliper assembly from the rotor without forcing it too much. i used a big C-clamp to compress the piston a bit to free it up. Next the rotor should just come off, or like in m case, a BFH comes in handy for this.
Now you can put on the new rotor and caliper assembly the same as the GT stuff came off, just bolt-up the new caliper assembly and use loktite on the bolt threads, and torqur to spec. Connect the new flex line to the caliper using the correct banjo bolt and 2 copper crush washers. Thread the other end of the flex line to the hard line on the inner fender and re-install the bracket bolt.
Thats all there is to it. Now bleed the whole system starting from the passenger side rear wheel and work your way up.
As for the rear, I just ended-up putting new pads and rotors on, and painted the calipers red to match the front. I couldn't justify pulling the axles (which involves removing the ABS sensor, which I heard horror stories about) and going through all that trouble for a small gain in braking performance. The front kit was worth every penny though.
Yobi1Kanobi
559
  • Jul 23, 2007
what is the difference in the brake lines
Engel
219
Jul 23, 2007
#10
  • Jul 23, 2007
  • #10
http://sn95brakes.cjb.net/
go-stang5.0
2,244
Glenview,Il
Jul 23, 2007
#11
  • Jul 23, 2007
  • #11
Pulling axles is pretty easy...just messy cuz you have to deal with smelly gear oil. But yea the baer rear kit isnt bad. Thats what I run and no problems with it. The rotors arent vented but I run a street pad and open track the car and have absolutely no problems with it. It costs a bit mor but not much and its another option.
94-302-vert
1,947
NE CT
Jul 24, 2007
#12
  • Jul 24, 2007
  • #12
With 2 guys pulling the axles is easy.. and it is nice to change out the diff fluid every once in a while too...
Fox Cobra wheels real vs. replicas
  • keel
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
keel
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
