Cobra/Bullit/Mach1- caliper upgrade?
The caliper bracket is the special bracket that moves the caliper out another 2".
All you really need to put Cobra brakes on a 94-98 car is the rotors, complete calipers with pads and a set of brake lines. (94-98 lines won't bolt up)
Thanks for the info.
Just a FYI- I plan on ordering a rear brake upgrade kit that will allow me to use the stock rear caliper on my GT with a 13" cobra rotor in the rear. So all around 13's :D Steeda sells a kit for 299. Baer sells one for 245. Brothers sells the baer for 245. and D and D motorsports sells the baer for 229. :nice:
67stang390 said:
94SC50 - Can you point me to the PPI website? I did a search and found www.mustangparts.com but it doesn't seem to be working, it just directs me to one of those ad search engines.
:shrug: It's a co. here in VA that supplies our local Stang club. I have no clue what happend to them ovewr the winter. I'll try to find out more info.
www.speedconcepts.net would be my second choice. They have some good prices on the brakes and I get a lot of stuff from them.
u need a cobra master cilynder and matching brake lines for it, without it you pedal is going to feel "funny" other than that, just make sure you order the banjo bolt and washer, its like 10 bucks with buyfordracing.com but you will need it and nobody else has em not even ford!!
i paid 40 bucks from from autozone, it was a rebuilt but it worked, also your going to need the brake lines for the master cilynder because the fittings are the same ecxept they are switched around, i had custom ss braided lined made for another 30 bucks plus they look really good. I dont know how much the ford ones are i didnt even check
