dizzy has nothing to do with the intake? I installed one on a 5.0 MN12 Cougar (same engine as the SN95)... But the engine would not run properly, I had a cylinder that would not work as if an injector wasn't working. Later I found out that I should have blocked off the EGR passages since the Cougar used the external EGR passage. If I would have installed it on a fox Mustang it would have worked at least that's all I can come up with. I installed the stock intake on the Cougar and the engine ran fine.
The problem I saw with my intake is the labels were on crooked, the casting was kind of fudged at the intake/head. I wouldn't get another one because of the EGR spacer being cast with the upper intake.
