  • SN95 4.6L Mustang Tech
cobra conv
  • Thread starter Thread starter badman602
  • Start date Start date Jul 23, 2006
badman602
  • Jul 23, 2006
i was looking for some info on doing a cobra converson to my 96 gt. what i am tring to find out is what is the diff from the non PI block and the cobra block. do the heads bolt up? is the trans mounts and fly wheel the same? i know that i will need to get a comp and harness. for the heads i will need front covers and chains and gears and stuff. what i am tring to find out is do the heads bolt up and can i stroke it to the 5.4 or is that a whole diff motor?
Superhereaux
chicks make me feel inadequate
538
South Texas
Jul 23, 2006
  • Jul 23, 2006
first you're better off getting a complete 4v engine. lots of little things would be needed and the cobra block is aluminum. there's alot more to it than that but thats the simple answer
trans mounts i assume would work. older gt's and cobras had the same tranny but the flywheel is different (6 bolt vs. 8)
no you can't stroke it to a 5.4
Outlaw97GT
234
Redneckville, Tx
Jul 23, 2006
  • Jul 23, 2006
Dude, you only need to make 1 post per topic...
I posted in your other same topic thread.
four six
506
Hobart, IN
Jul 24, 2006
  • Jul 24, 2006
PI block and heads=
4V Cobra block and heads=
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
