  • 1994 - 1995 Specific Tech
Cobra heads
  • Thread starter Thread starter jg22
  • Start date Start date May 1, 2011
jg22
26
  • May 1, 2011
I have a 95 GT, stock for the most part except for flows, o/r h pipe, msd ignition etc. Anyways I have a set of heads off a 95 cobra, waste of time putting them on my GT? Better off just selling?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
May 1, 2011
  • May 1, 2011
Total waste of time. You won't gain enough power to justify the cost of new head gaskets.
Kurt
blksn955.o
3,263
st.louis mo 314
May 1, 2011
  • May 1, 2011
Depends on what your goals are. Dont expect much but if you got them for around $200 and get them cleaned up for under $150 it wont be too bad. Dont expect to end up with the same results if you went with say AFR 165's or TFS fast as cast heads or something.
FWIW with box stock take off 95 cobra heads, TFS1 cam, ported stock lower gt intake, no tune I went 13.5 @ 102 with a crap 2.3-2.4 or something 60ft on $80 regular street radials (best 60ft on those tires was 1.93 or something).
Check out the 300rwhp gt40 thread.
Useless no, there may be a better route but if iron gt40's fit your needs, take off's are better than stock E7's.
jg22
26
  • May 1, 2011
Thanks for the info, I got the heads for $50 by the way which was the only reason I picked them up. Still unsure what I'll do with them.
WhiteCobra95
635
177
74
May 1, 2011
  • May 1, 2011
If you have the time and talent, the iron GT40's do well ported. But like everyone says, there are significantly better aluminum aftermarket heads out there if you have the money.
The production iron heads can make good power with very well matched combos. A good friend of mine built an '86 302 with ported iron GT40's, '94 cobra cam, 1.7:1 rockers, long tubes, 3.27 rear, FM GT40 intake, t5, and ran 13.2's @ 104 with wheel spin through first and part of second in his '86 convertible. That was with a mostly stock suspension and the late 90's BF drag radials.
jg22
26
  • May 1, 2011
That's pretty dang good. I think I'm just going to end up going with some GT40p heads, e303 cam, & trickflow or cobra intake. Seems like a good way to make some power without a ridiculous amount of cash.
alleymad95GT
204
Okemos, Michigan
May 2, 2011
  • May 2, 2011
Your post is implying you are going to buy GT40p heads??? Why would you do that??? You already have the GT40s...unless they are broken or something...
If you want iron heads and are happy to know that the absolute best you will ever get out of an N/A combo based on stock parts is right around 300 rwhp, use the ones you already have...
Also, FWIW, I would steer clear of the letter cams...you can do better than the E cam...your stock cam with 1.7 rockers is better than the E cam, IMHO...
Just my two cents...
WhiteCobra95
635
177
74
May 2, 2011
  • May 2, 2011
I have to agree. For the money you would spend on a ready-to-run set of GT40P's, you could probably find a shop to CnC your E7's (or at least you can in MI) and do a lot better across the board on torque and power. Some people like the GT40P's since they're usually cheaper than other performance heads, but I would put the same amount of money into the E7's or the GT40's you already have before I would invest in P's.
BTW: My friend's convertible weighed in around 3,300 w/o driver, ran 89 midgrade (because he was cheap about fuel), and had a really good tune/calibraiotn with an 80mm MkVIII MAF and 24 lbers. We estimated about 330 at the flywheel and around 300 at the wheels. He added 400lb crane valve springs to spin it just shy of seven, and put nearly 100k miles on engine doing that. There's something to be said for finding a happy combo of stock parts (or production based parts) that work well together for saving money and adding some durability.
Good luck with your build, those are some tough choices
99FiveOh
2,051
20
99
J-Ville, FL
May 2, 2011
  • May 2, 2011
Of course if you are planning to huff some air into that motor the GT40 irons will be right at home.
Curious, do the 94/95 Cobra heads have the thermactor ports in the exhaust ports? I know the set of P's I got from a late exploder didn't have them. I know for sure that's a big power killer, you can't even get your finger into the exhaust ports with the smog ports in there!
blksn955.o
3,263
st.louis mo 314
May 2, 2011
#10
  • May 2, 2011
  • #10
Cobra GT40's have the ports. Also the non P's can be ported further due to the P's having the water passage closer.
My thumper ported exh. ports I like showing off.
99FiveOh
2,051
20
99
J-Ville, FL
May 2, 2011
#11
  • May 2, 2011
  • #11
those are purdy!
pwcracer
347
Hastings, MN, USA
May 3, 2011
#12
  • May 3, 2011
  • #12
I had the cobra GT40's on my old setup and was shocked at how much boost I lost when I switched to a cheap set of performers (Better flow). On the plus side I was able to sell the GT40s rather quickly to a guy that wanted them for a stock class race car.
hollywoodstang
1,095
May 4, 2011
#13
  • May 4, 2011
  • #13
I bet these heads have more then a grand in it. I like Iron better on the street then aluminum heads. It's cool too, lol
blksn955.o
3,263
st.louis mo 314
May 4, 2011
#14
  • May 4, 2011
  • #14
I got a big hookup from Thumper but the work would have been in the $650 ballpark (same cost as he charges for E7 work). I already had springs on the heads spec'd out for the TFS1 cam and up to 1.72rr. I had paid for a spring, valve job, mill, cleaning refresh a year or so before Thumper got them and that refresh was REALLY close to what Thumper charges to refresh and port...since he also mills, does a valve job, and as you can tell not only cleans them but paints them.
Honestly, even if the gains were only marginal to unported...cost wise might as well ship to have ported and refreshed if the end cost is going to be not too far off from having them refreshed alone.
These heads and the 175 shot put me well within the power range to break a lot of things...and just under the block splitting level, maybe even enough to split the sucker if I get greedy. That is enough for me and the irons fit my needs.
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
D
What's it Worth? Considering Selling '82 Fairmont Futura Body Shell
  • DonMay63
  • Apr 5, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 5, 2026
DonMay63
D
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 3:12 PM
General karthief
