  • SVT Tech Forum
COBRA IN TROUBLE NEED HELP
  • Thread starter Thread starter big nasty
  • Start date Start date Mar 31, 2004
big nasty
65
Montezuma, GA.
Mar 31, 2004
  • Mar 31, 2004
i gave my car a tune up about a year ago (~10000 miles ago). new fuel filter, motorcraft copper plugs (22C) gapped .54, live wires, sreamin demon coil packs, cleaned fuel injectors. now my car has it 100000 miles and now it falls flat on its face at about 5800-6000 and will not go past that. does anyone know what the problem could be and any suggestions on how to fix it?
thanks
__________________
9
98cobrancali
70
Norco, CA
Mar 31, 2004
  • Mar 31, 2004
imrc's could need a cleaning
C
Chris Doss
133
  • Apr 1, 2004
Check you plugs, that almost sounds like spark blowout. Is the gap of the plugs still at .054?
C
Chris Doss
133
  • Apr 1, 2004
If you really have to delve into this, try replacing your coil packs and wires back to stock and see if you still have the problem (assuming you still have these around)
Str8Pimp'n
492
Str8 outta Compton...
Apr 1, 2004
  • Apr 1, 2004
Have you checked for any computer codes? The EEC-V may or may not show the IMRC failure.When the secondaries do not open up, the engine effectively starves for air at the high rpm band. If you do decide to clean the IMRC plates, might as well pick up a new IMRC controller box. Fordparts.net carries them for around $80. If you suspect an ignition problem, maybe try putting on the coils first, since those are the easiest to change over. But it sounds to me that you have had this ignition setup on for a while and the high rpm problem just started. Do a proper diagnostic first.
Tat98Cobra
681
  • Apr 1, 2004
thanks__________________
You're probably experiencing Spark Blowout - some part of your ignition system has failed. Most likely one of the coil packs. The stock ones are the best for 96-98 cobras, bar none, even for power adder applications
peace
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
3K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
Progress Thread Nicholase "lights out" build-
  • nicholase
  • Aug 10, 2024
  • 26 27 28
41K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 27, 2026
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
  • SVT Tech Forum
