Newer injectors are "pencil tip" style and much quieter than the old noisy "fat body" injectors. They're physically the same length and will install in exactly the same fashion. You will need the adapter for the new, to old style plug connectors though. Mass Air meter should work to, but you'll need to have the ECU reprogrammed. The injectors and MAF on the later model mod motors aren't calibrated to one and other like they are on the old 5.0L OHV engines. The Mass Air Meter transfer function is programmed directly into the ECU.
