  • 1994 - 1995 Specific Tech
Cobra Intake Swap
  • Thread starter Thread starter KTD SC
  • Start date Start date Aug 1, 2004
KTD SC
99
New York
Aug 1, 2004
  • Aug 1, 2004
Hello everyone, Im going to be doing a cobra intake swap on my 94 gt today, and i just wanted to see if anyone had a few tips to make it go buy faster or whatever.
Also the supplies i Have with the intake manifold are:
Gaskets inbetween the lower manifold and the heads
Gasket for inbetween the Lower and Upper
All Hardware
Someone told me i need RTV Silicone stuff to put all around the lower manifold or something also.... is there anything else?
thanx
-ken
OrangeMustangGt
1,976
Cape Cod, MA
Aug 1, 2004
  • Aug 1, 2004
yeah on the front and back, where its inbetween the heads, put pleanty of rtv on the corners to hold those small gaskets. Otherthan that, make sure the surfaces are clean so coolant wont go into ur oil from a leak.
94TURBO5 O
2,509
VA
Aug 1, 2004
  • Aug 1, 2004
Do a search there is plenty of advice there as well as the FAQ.
Good Luck.
HoofnIt
1,175
North Carolina
Aug 1, 2004
  • Aug 1, 2004
While you have stuff apart I would put in a new thermostat. I had to go to Lowe's and purchase a few plugs for the lower intake that were not supplied. Make sure you replace any cracked or hardened vacuum lines. Good Luck!
Darrin
184
Cocoa, Florida
Aug 7, 2004
  • Aug 7, 2004
R.t.v in the corners and don't use the gasket kit with the cork ends. The rubbers are the best. Now for something I just went thru. While you have the lower manifold off, assuming it's used, pull the pcv out, remove the pcv sleeve, look into the hole. There is a kind of mesh inside. This is a "filter" . REMOVE IT. The one I got was carboned up and after the install I had so much crankcase pressure it pushed the dipstick out. An old ford tech told me when the "filter" clogs enough it will blow the seals, pan gasket, etc. I pulled the upper, removed the screen mesh inside(pain in the) re-assembled it and no pressure. He told me as long as you change your oil and pcv like you should you'll never need the "filter".
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 7, 2004
  • Aug 7, 2004
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 7, 2004
  • Aug 7, 2004
That's not a filter. It is designed to keep the oil in your crankcase, instead of in your intake tract. If you're worried about it being plugged, hose it down with carb cleaner.
C
cmozez
450
Tupelo,Mississippi
Aug 8, 2004
  • Aug 8, 2004
Now that you have done it. Throw us some tips. I'm going to be doing mine soon.
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Engine Re-torquing intake manifold bolts question
  • 91GTstroked
  • Feb 22, 2025
Fox 5.0 Mustang Tech Mar 1, 2025
Jarhead67
J
