Cobra MAF
  • Thread starter Thread starter PJB
  • Start date Start date Sep 20, 2006
1 of 2 Next Last
P
PJB
131
Rotterdam, NY
Sep 20, 2006
  • Sep 20, 2006
Would this be of any benefit to my '92?
http://cgi.ebay.com/ebaymotors/1993...0QQihZ008QQcategoryZ33557QQrdZ1QQcmdZViewItem
I have the 19lb injectors on my car.
A few people have told me to get a bigger than stock MAF for more power.
I currently have a 70mm throttle body on the car.
vristang
4,933
101
124
Seattle
Sep 20, 2006
  • Sep 20, 2006
Basically, that is the same thing you have.
What you have is a 70mm MAF from a 94-95 Mustang?
jason
stang&2Birds
2,091
New England. :-) CT/MA
Sep 20, 2006
  • Sep 20, 2006
It's STUPID, MORONIC, and a ***LIE***!!
First:
#1:
ALL FORD ELECTRONICS ARE CUSTOM TUNED FOR A SPECIFIC UNIQUE MAF-BODY
(That's why C&Ls are a JOKE!!!!)
#2:
The electronics for a fox 55 MAF are tuned for the airflow that goes through the sample tube of a fox 55 MAF.
#3:
It "works great on his car". Well, it may KINDA/SEMI work. Like the POS JOKE C&L MAF's "work". Unless you read ALL of the trim values (you can't even do that with the Tweecer) and use a wide=band, a person can **NOT** say that "a MAF works".
If you want a better MAF, go with the 94/95 Mustang MAF and a 70mm adapter. Or go with a PMAS (the new ProM).
It's a POS sold by someone that is either totally clueless about MAFs or someone that KNOWS they are SCREWING people.
Last: Note on the ebay auction:
This is a private listing. Your identity will not be disclosed to anyone except the seller. If you are already bidding on this item, view your bidder status.
P
PJB
131
Rotterdam, NY
Sep 20, 2006
  • Sep 20, 2006
I have the stock MAF now and a MAC 70mm throttle body, not a 70mm MAF sensor.
P
PJB
131
Rotterdam, NY
Sep 20, 2006
  • Sep 20, 2006
stang&2Birds said:
It's a POS sold by someone that is either TOTALLY CLUELESS or someone that KNOWS they are SCREWING people.
For ONE THING:
(That's why C&L are a JOKE!!!!)
#2:
#3:
Last: Note on the ebay auction"
So this part is worthless?
What is C&L?
Im basically new to modifying cars like this so Im a little clueless when it comes to certain things. I just know that a few people told me to upgrade to a bigger MAF. I know I have to match it to the injector size but I thought if I bolted/hooked this part up thats all I have to do.
I thought stock was smaller than 70mm.
stang&2Birds
2,091
Sep 20, 2006
  • Sep 20, 2006
What is C&L?
I'm basically new to modifying cars like this so I'm a little clueless when it comes to certain things. I just know that a few people told me to upgrade to a bigger MAF. I know I have to match it to the injector size but I thought if I bolted/hooked this part up thats all I have to do.
It's WORSE than worthless! A C&L is an aftermarket POS MAF. BOTH a C&L and that JOKE of a MAF on ebay can RUIN your engine. Unless someone has a Tweecer to read the gross trims and go on a Mustang-type Dyno, NO ONE can even come close to saying that a "MAF" works - NO ONE! PERIOD!
Then, as I said above, there is NOT an public product available to read the 2 dimensional trim table that the EEC uses in normal driving. The Tweecer (an aftermarket EEC add-on) can read only the gross trim values.
I've been designing control/response systems for over a dozen years.
You should NOT "just" use a "calibrated MAF". For one thing, THERE IS NO SUCH THING AS A MAF "calibrated for injectors". It's PURE AND TOTAL BS!!!!!
If you REALLY REALLY need 24's (IMHO, MOST people do it for the RICER reason of saying "I've got 24's"), then spend the $300 and get a chip. If someone NEEDs 24's and "can't afford" a $300 chip, they are FULL OF IT! Hmm, spend $5K on mods, but not $300 to get the most out of the mods? WTF????
To see some VERY BASIC info on MAFs, injectors, and how they are used in REAL LIFE (not the BS "make believe world" than many seem to live in), read the article by Mike W:
Mike W was the one that did the first aftermarket "Stang Chip" and then offered the first software for professional dyno tuners.
http://www.mustangworks.com/articles/electronics/InductionBlues.html
stang&2Birds
2,091
Sep 20, 2006
  • Sep 20, 2006
I should add that a number of people run 24's and the BS "calibrated MAF" (which is a LIE), and they are "happy". They even pass smog tests. That's fine. Still, IMHO, unless they have a car that is used on for quarter mile runs, they aren't getting the full potential from their setup.
If you NEED to go to 24's and don't want a chip, the get a 93 Cobra MAF and EEC. Note, that's ONLY for 1993 Cobras - NOT 94 or 95 Cobras. The 93 Cobra EEC is setup internally for 24's and has the MAF transfer map of the 93 Cobra MAF. The "93 Cobra MAF" was first used on a T-bird and has been used on engines that have other injector sizes. It's the MAF map *inside* the EEC that is important (x-volts means y-air_flow).
P
PJB
131
Rotterdam, NY
Sep 20, 2006
  • Sep 20, 2006
I just read over that and saw this:
As far as MAF sensors go, the 55mm sensor on a 5.0L Mustang should be the first thing to go, as it can limit the amount of power the engine is capable of making.
So the article is saying to get a bigger one but then says they fool the computer and thats bad.
I have 19lb injectors and never mentioned wanting 24lb injectors. I just want a better MAF to use with stock size injectors. Im not trying to play with the computer or anything.
I found the article a little confusing, but most tech articles seem to confuse me a bit.
stang&2Birds
2,091
Sep 20, 2006
  • Sep 20, 2006
BTW: Welcome to Stangnet. I'm infamous for beating up on many EFI beliefs. That's fine. I not on the forums to be super friendly with everyone. I post so that people can get some REAL info from someone that has a degree (MS) and experience in the field.
For over 10 years, I was getting DEATH THREATS on the forums because I was telling people to STOP WITH THE RICER MOD of "adjusting the TPS". Yea, people WANT their RICER MODS!
BTW: My FAQ on the TPS:
http://www.veryuseful.com/mustang/tech/engine/Mustang-TPS-FAQ.html
if you want some EEC info, a place to start is:
For Engine, Fuel Injection, and EEC, see:
http://www.veryuseful.com/mustang/tech/engine#EEC
Some articles to start with:
A Quick Overview of the Inner Workings of the EEC (Mustang Fuel Injection Computer), by TMoss:
HTML/web version: http://www.veryuseful.com/mustang/tech/engine/EECIVInnerWorkings/
PDF version: http://www.veryuseful.com/mustang/tech/engine/EECIVInnerWorkings.pdf
A GREAT, IN DEPTH, Very Technical, Reference for the EEC IV. A MUST READ!: http://www.veryuseful.com/mustang/tech/engine/eec-IV-Tech98.zip
At least read the one that Tmoss did. He did a a GREAT intro to the EEC-IV for people.
stang&2Birds
2,091
Sep 20, 2006
#10
  • Sep 20, 2006
  • #10
Correct. The calculated load is incorrect. This value is used by the EEC until the *slow* O2's (oxygen sensors) catch up with any change in load or engine speed. So, the delivered fuel WILL be off. Even the wide-band O2 sensors that dynos use are TOO SLOW to see the lean condition.
If ALL of the stats are captured and then analyzed, the error in fuel calculations will be seen. Or, the laser-based 02 detectors (and other $$$ methods used by Ford and other companies) would see the poor air/fuel ratio from the engine.
Once again, a number of people are HAPPY with their 24's and "calibrated MAF" without a chip. It works well enough for them. That's fine.
stang&2Birds
2,091
Sep 20, 2006
#11
  • Sep 20, 2006
  • #11
PMAS - ~$300.
Or, get a 94/95 70mm MAF and a 70mm square mount to round adapter.
Here's a picture (~1M) of the 55mm Fox MAF, the 90mm LMAF (requires a chip), and the 70mm 94/95 MAF.
http://www.veryuseful.com/mustang/tech/tmp/mafs-fox-LMAF-94.jpg
Here is a 70mm mounting adapter that I and others have used.
http://www.kustomz.com/cat3.html
70MM Adapter TR70 44.95
Other companies used to also offer the adapters. As of TODAY, this is the only 70mm mounting adapter that I know of.
If someone knows of ANY others, PLEASE let me know!
P
PJB
131
Rotterdam, NY
Sep 20, 2006
#12
  • Sep 20, 2006
  • #12
Thanks. Ill read over those but cant guarantee Ill be able to make nearly as much sense out of them as you can.
I was previously told to adjust the TPS because it throws a code and CEL occasionally. I never actually did it because my meter doesnt work right for some reason.
P
PJB
131
Rotterdam, NY
Sep 20, 2006
#13
  • Sep 20, 2006
  • #13
stang&2Birds said:
PMAS - ~$300.
So all Id need to do is buy a stock '94/'95 MAF and the adapter and it will work? Or do I still have to reprogram the computer?
Will it work with my BBK fenderwell cold air intake?
Sorry for all the questions and possibly sounding stupid and/or repetitive.
stang&2Birds
2,091
Sep 20, 2006
#14
  • Sep 20, 2006
  • #14
because my meter doesn't work right for some reason.
For a 100% stock *correctly* setup TB, you will NOT get a CEL.
People up the idle speed to compensate for cams and bigger injectors. People also use a NON-FORD TB and/or TPS. In those cases, the TPS must be adapted to the NON-STOCK setup. A non-adjustable part can not be "adjusted". Of course, people prefer their RICER mods so they can brag about their SOTP (seat of the pants) gains, getting 3000HP, and a million MPG.
Yea, what ever! If anyone posts BS like that and they have a Computer Engineering degree, send them to me, I'll slap them upside their head.
To be FAIR, most people are trying to be HELPFUL and they are repeating INCORRECT info that they read/heard from someone else. Almost never do people pull BS from their rear-ends and post it on the forums. SOMEONE ELSE LIED TO THEM! Then, they were trying to be HELPFUL. Blame the SOURCE first and foremost!
P
PJB
131
Rotterdam, NY
Sep 20, 2006
#15
  • Sep 20, 2006
  • #15
To be FAIR, most people are trying to be HELPFUL and they are repeating INCORRECT info that they read/heard from someone else. Almost never do people pull BS from their rear-ends and post it on the forums. SOMEONE LIED TO THEM! Then, they were trying to be HELPFUL. Blame the SOURCE first and foremost!
I have a MAC 70mm throttle body on the car. It does throw the CEL for TPS voltage too low.
vristang
4,933
101
124
Seattle
Sep 20, 2006
#16
  • Sep 20, 2006
  • #16
stang&2Birds said:
#3:
Joe-
You have posted before that you don't like the C&L meters.
Can you elaborate as to why?
All I ever hear is that they aren't accurate, but have never seen any justification for that claim.
Thanks,
jason
R
Reed
78
BC, Canada
Sep 20, 2006
#17
  • Sep 20, 2006
  • #17
I have a question about MAFs as well and I can't seem to a get an answer. I have a Cobra MAF waiting to go in the car eventually, and I want to know exactly what I need. As I see it, there are 4 parts to the MAF swap:
1)Cobra EEC-IV
2)24 lb/hr Injectors
3)70 mm Tube
4)?? Air Meter
When I say "Air Meter" I'm referring to the black electronics mounted to the tube which have the two wires attached. Do I need the Cobra specific part for this, or will the "Air Meter" from my '93 work as long as the other components are correct? Does the Cobra EEC-IV assume a 70mm tube, or does it need the little black "Air Meter" to tell it there is a 70mm tube?
Not sure if this is clear, I'll try once more. Do I need a Cobra specific air meter or will my stock air meter work with the tube?
vristang
4,933
101
124
Seattle
Sep 20, 2006
#18
  • Sep 20, 2006
  • #18
You are asking about the MAS - Mass Air Sensor.
At least that is what I call it.
You do need the 93 Cobra specific MAS. Only way to make it work.
jason
R
Reed
78
BC, Canada
Sep 21, 2006
#19
  • Sep 21, 2006
  • #19
Well, thanks for the answer (sorry to jack the thread). That's kind of crappy though, since I have the tube with the wrong MAS attached. It's going to be a pain to find the correct one.
I don't think so, but can the MAS be bought separate from the tube from Ford. I know 92-95 SC T-Birds used 70mm MAFs and this is where the Cobra borrowed it from. (F1CZ-XXXXX-XX)
vristang
4,933
101
124
Seattle
Sep 21, 2006
#20
  • Sep 21, 2006
  • #20
According to this...
http://rothfam.com/svo/reference/maf_part_number.html
You are looking for a F1SF MAS.
jason
1 of 2 Next Last
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
