Cobra oil pump, GT pan?
TweekedGT
1,274
Alberta
Hey guys! Will a Cobra oil pump work in a GT pan. I mean specifically will it drain the pan because it is higher volume? I don't want to have no oil pressure because the pan is run dry. My GT takes 6L of oil. How much does a Cobra take or does it's pan hold any more?
droptopponynj said:
i thought they were the same except the 2 scrapers in the front of the cobra.
no its the same pan, part # and all(XR3Z-6675-DA) no difference in 1997 to 2004 oil pans on SOHC's & DOHC's and the only thing that makes the 1996 pans different than the 1997 up is 1996 pans have a "low oil sensor" in them which was dropped for 1997 production.
droptopponynj said:
So I guess I don't need to upgrade to a Cobra pan after all. I'll just add the windage tray.
Thanks Randy.
well yes, if you get the full length windage tray from Canton, but the factory DOHC tray is not worth the effort IMHO as you need different studs, spacers and nuts to attach it and it only covers the sumped part of the oil pan..
hmm, i got a 98 and there was an oil sensor, same with my other friend that has a 98
do the mark 8's have that sensor too?
i'm kind of glad SVT is done, their are losing it. they told me there was a difference :rolleyes:
