  • SVT Tech Forum
cobra problems
  • Thread starter Thread starter TRPLBLAKSVT
  • Start date Start date Apr 23, 2009
T
TRPLBLAKSVT
Arizona
Apr 23, 2009
  • Apr 23, 2009
Whats goin on fellas? I have a 97 cobra vert with all the major bolt-ons and ive been havin some probs. Ill fire the car up n it'll run just fine until it gets up to temp then itll start runnin like ****. It will start missin and just run rough, if I kill the car and let it cool for a few ill try and fire it up, it will fire and immediatly start missin and die even gining it gas, almost seems like its loosin fuel pressure along with somethin in the ignition, the problems almost exclusivly happin when the car is up to temp, but its not overheating.. can anyone one help??
LaserSVT
3,542
233
Apr 23, 2009
  • Apr 23, 2009
Could be a number of things. You need to test fuel pressure. Also, is it throwing any misfire codes? If so then you prolly have a coil pack going out. Check your plugs too and see how well/bad they are burning.
T
TRPLBLAKSVT
Arizona
Apr 23, 2009
  • Apr 23, 2009
its throwing a lean cod for both banks, and the coil packs are new changed em a lil while ago ago when this first popped up
LaserSVT
3,542
233
Apr 23, 2009
  • Apr 23, 2009
Ah, clogged fuel filter is what I would first check.
Then check the fuel pressure regulator. Do you have an off road h-pipe?
Also the O2s may be dying. Fuel pump is another thing tio check. You need a fuel pressure gauge.
T
TRPLBLAKSVT
Arizona
Apr 24, 2009
  • Apr 24, 2009
ya man im checkin the fuel pressure tomorrow it threw two misfire codes and system too lean for both banks but the coil packs are new thats what I thought the prob was initially but it wasnt Is got n off road just changed the mils but not the O2s plannin on doin that tomorrow as well
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
D
95 cobra (stock) Fuel pump or Distributor?
  • drop5ohhh
  • Jul 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 1, 2025
gkomo
TTSaleen's Foxbody Project
  • TTSaleen
  • Apr 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
TTSaleen
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
  • SVT Tech Forum
