Of I wanted to put the Cobra Speedometer in my GT or V6 what would I have to do? Weren't they mechanical in '95?
You need to have faces that match the gauge, of course. A Cobra cluster is a drop-in replacement for a GT or V6, and no the tach and speedo won't be off if you swap. The EEC is independent from the cluster, you don't need to swap in a Cobra EEC to use a Cobra cluster.stlboarder said:I guess I'm pretty much asking is: wouldn't I need the whole cluster not just the face? AND if I used a Cobra computer would it effect the speedometer. Like if I put used a Cobra computer on a GT.
viperos said:... you're gonna have a hell of a time w/o a moders mustang w/ the digital option in it...
, it will be difficult... you will have to drive through a radar trap, and set the needle on your gague that way, and I don't even know how you're going to do it for your tach...And then you're as (in)accurate as he is.randomjoker said:Speedo: Have a buddy drive side by side with you on cruise control and set the needle.![]()
