  • SN95 4.6L Mustang Tech
cobra swap
  • Thread starter Thread starter gotchopsticks
  • Start date Start date Aug 17, 2005
G
gotchopsticks
315
  • Aug 17, 2005
i have an 02 gt, and i might be getting a cobra engine and tranny. what would i need to do to make everything work. the engine and tranny will have all electrical, belts, etc...the whole 9 yards. will my o/r x-pipe still fit? or will i need a new one? thanks for the help.
G
gotchopsticks
315
  • Aug 20, 2005
bump
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
1) If you want a Cobra, f'n buy one.
2) Use the forum search feature and Google
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
  • Aug 20, 2005
no need to be an asshat.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
  • Aug 20, 2005
It should be a pretty simple swap. The hardest part being the wiring harness. Does it also come with the ECU and all the intercooler plumbing, tank, and pump?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 20, 2005
  • Aug 20, 2005
sorry...
G
gotchopsticks
315
  • Aug 20, 2005
the car is complete, but totalled. so i can get anything from the car i want or need. engine, tranny, ecu, air-box, etc... everything is there. if needed, i am willing to swap wireing harness from head lights to tail lights. thanks for the help.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
  • Aug 20, 2005
sounds good. was it a front end collision? In that case you may have to find some of the supporting parts elsewhere.
G
gotchopsticks
315
  • Aug 20, 2005
no, it was hit from behind, then managed to flip...luckily for the driver it wasnt a vert. but what will i need to do to make everything work? will everything bolt right up? will the brakes fit without modification?
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
#10
  • Aug 20, 2005
  • #10
Everything should bolt up ok, it's just going to be ALOT of work. It's not as simple as just pull the old out, but the new in. The hardest thing I can see is like I said before, the wiring harness. Just take your time and go slow. I hope you don't plan on doing this in a weekend. It will most likely turn into a few week project. If you take the motor and Tranny, make sure you take the driveshaft too, as it is different then the GT's. As far as the brakes, I think they should bolt right up. The Cobra and GT both use 17in. rims. You'll need to grab the rotors too. Hope this helps out! Check out www.modularfords.com , a few guys over there have done this swap.
G
gotchopsticks
315
#11
  • Aug 20, 2005
  • #11
well im going to be loosing my license for a while. im 17 and i got a 100+mph speeding ticket...so its gunna be a while, and i figure i will have plenty of spare time. so thanks for the help.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
#12
  • Aug 20, 2005
  • #12
And you want a terminator motor!!!! YOUR NUTS!!!! That sucks bro..........
G
gotchopsticks
315
#13
  • Aug 20, 2005
  • #13
what can i say? cant pass up a chance like this, plus i need to stay ahead of my import friends that are now using turbos. the funny thing is i can still beat some of them and im n/a will need to run premium fuel no matter what? say i get one of those nifty switch-on-the-fly tuners and retard my timing a little on one of the tunes, can i run super or regular? thanks
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 20, 2005
#14
  • Aug 20, 2005
  • #14
run NOTHING but premium w/ a cobra motor........period.
G
gotchopsticks
315
#15
  • Aug 20, 2005
  • #15
why is that? what do u think my milage will be if i leave it all stock and drive easy. i.e. shift before 2k and cruise at 1700-2k on the frwy?
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Aug 20, 2005
#16
  • Aug 20, 2005
  • #16
What kind of hp numbers can be expected from a bone stock 03-04 Cobra?
tdaily2
75
Greenville,SC
Aug 20, 2005
#17
  • Aug 20, 2005
  • #17
the easy way to do the swap is to drop the motor with the k-mimber and the barkes and trans then that way all you will have to do is put the car around the motor and go not have to work over the top of the finders
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Tuesday at 7:10 PM
LILCBRA
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
