cobra trans or tr 3650
The t56 swap is a little more complicated than just putting it in. I heard there are alot of parts involved in the swap. But if you have everything, 1500 is a great deal on it and it is a better transmission.
Yeah...NO! ;) Basically you put the trans in, use new crossmember or mod stock one/relocate (older model year cars), use a cobra driveshaft, aaannd...yer done ;) You can reuse stock clutch, clutch fork, TOB, all that if you want. You will need to wire up the reverse lockout to a switched 12v source or your brake pedal light switch. It's pretty straight forward, about as straight forward as a T45 --> 3650 swap.
