Cobra Wheels
93 Cobra 17" turbine style rims, or Cobra R's? Weren't the disc brake rear ends on the 93 Cobras slightly wider than the stock drum brake rear ends? If so, I'd think that the 93 Cobra rims and tires you're proposing would work fine on a drum brake rear end.
You are forgetting the important details. What offset and backspacing? Are they from a popular manufacturer? Probably are, in that case, they will work fine in either 24mm or 36mm offset. What are you using for rear axles? This all makes a difference in fitment, seeing how the Fox wasn't exactly made for large wheels.
