Code 15?
  • Thread starter Thread starter theconductor
  • Start date Start date Jul 18, 2008
theconductor
337
96
74
Roseville, CA
Jul 18, 2008
  • Jul 18, 2008
I just pulled code 15 from my car. I have been having problems with an intermittent CEL. I thought for sure that jrichker had just posted a help with code 15, but I can't find it in the search.
Anyone had this code? What to do...
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 18, 2008
  • Jul 18, 2008
code 15 is "ROM test failed" AFAIK its a common code when having a chip installed in the j3 port. do you have a chip??
if not then i dont know someone else will have to chime in.
my car threw code 15 out at me and the guys at EECtuning.org say that codes pops up alot with a tuner, i just tuned it out with my tweecer so it wont showup.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 18, 2008
  • Jul 18, 2008
As requested...
Code 15 - No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test
Failure). The voltage to the Keep Alive Memory (KAM) is missing (wiring problem)
or the KAM is bad. The KAM holds all of the settings that the computer "learns" as
it operates and all the stored error codes that are generated as a result of
something malfunctioning while the engine is running. Use a voltmeter to check
the voltage to the pin 1 on the computer - you should always have 12 volts. No
constant 12 volts = bad wiring. If you do always have the 12 volts, then the KAM is
bad and the computer is faulty.
If the computer has to "relearn" all the optimum settings every time it powers up,
the initial 5-30 minutes of operation may exhibit surges, poor low speed performance,
and rough idle.
Note that some aftermarket chips will cause code 15 to set. Remove the chip,
clear the codes and retest.
Before replacing the computer, remove the battery ground cable for about 20
minutes. This will clear all the codes. Retest after several days of running. If the 15
code is gone, then don't worry about it. If it is still there, then you get to do some
troubleshooting.
Wiring diagrams for the proper model years are next…
For 86 models see http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
For 87 models see http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
For 88 models see http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
For 89-90 models see http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
For 91-93 models see http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
See the following website for some help from Tmoss (diagram designer) & Stang&2
Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information
theconductor
337
96
74
Roseville, CA
Jul 19, 2008
  • Jul 19, 2008
Thank you both for the reply. I do have an aftermarket chip. Just got it installed about 2 weeks ago. I will check the 1 pin if the reset doesn't work.
If not maybe I will try what foxfan suggested and take it to the tuner to burn out the code 15
Thanks again,
kyle
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
