  • 2.3L (N/A & Turbo) Tech
Code 224...'92 Mustang 2.3
  • Thread starter Thread starter tbirdchick
  • Start date Start date Jun 11, 2005
T
tbirdchick
  • Jun 11, 2005
Hi, my name is Jan and I'm a 54 year old female who has been playing mechanic all of my life. I've got a '92 'Stang here with an intermitent ignition problem. It'll be running fine, then the tach will drop to zero and the motor will run roughly. Then often the tach starts working again and the miss goes away. So after attaching my code scanner in KOER mode, it threw two codes....998 (Hard Code) and 224 (IDM malfunction). I know that the IDM monitors the ignition input to the PCM, but haven't a clue where my problem lies. So far, the only thing I've tried is pulling the SPOUT, with dropped the tach to zero and made it run rough. This is the first DIS system I've worked on. Any and all suggestions as to where to check next would be greatly appreciated....
Thanks,
Jan
Dr_EluSivE
2,155
Central Illinois
Jun 11, 2005
  • Jun 11, 2005
its probably the DIS module, its bolted on the side of the Intake and has 2 plugs going to it. When the tach Acts up the DIS module usually seems to be the culprit.
Dr.
T
tbirdchick
  • Jun 11, 2005
Thanks! I assume that Advance A/P can test these as they can a TFI module?
R
RustBucket
585
Buford, GA
Jun 11, 2005
  • Jun 11, 2005
Yes they can, but have them run the test several times to allow the module to heat up. 9 times out of ten if the tach starts acting erratically and codes 223 and/or 224 show up its the DIS module.
T
tbirdchick
  • Jun 11, 2005
Will do. The guys there ALWAYS test everything I take in several times just to be sure.
Thanks,
Jan
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 19, 2026
CAMTWO1070
L
2.3 Code 222 No Tach
  • lespaul4563
  • Jul 21, 2024
2.3L (N/A & Turbo) Tech Jul 21, 2024
lespaul4563
L
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
