  • 1994 - 1995 Specific Tech
Code 327
  • Thread starter Thread starter hollywoodstang
  • Start date Start date Feb 1, 2009
hollywoodstang
1,095
Feb 1, 2009
  • Feb 1, 2009
Hey guys.
Today when i was pulling away from gas station. My CEL light came on and when away real quick!
When i pulled the code it happens to be 327.
It has something to do with EGR. I changed the EGR sensor. But never changed the ERG valve. What do you think it is?
Thanks and let me know
HISSIN50
34
129
Feb 2, 2009
  • Feb 2, 2009
What does the position-sensor baseline at? Be sure the electrical connector is clicked tight.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 2, 2009
  • Feb 2, 2009
Sometimes the EGR gets full of crap, and it doesn't open or close all the way.
Kurt
hollywoodstang
1,095
Feb 2, 2009
  • Feb 2, 2009
What is the proper way to clean the egr valve?
thanks
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 2, 2009
  • Feb 2, 2009
I usually just replace it or delete it.
Kurt
HISSIN50
34
129
Feb 2, 2009
  • Feb 2, 2009
I would not touch the EGR valve itself. This should be a sensor or electrical issue. A couple of minutes with your meter will tell you where your issue is.
FWIW, I use a bore brush to clean the EGR (future reference).
hollywoodstang
1,095
Feb 2, 2009
  • Feb 2, 2009
I changed the sensor already. So i am Is it a VALVE then?
hotcobra03
poteet,tx
Feb 2, 2009
  • Feb 2, 2009
code 327?
as hission50 has already said ,a simple check with a volt meter will tell you....your code is for low volatage,,the egr part is where to start looking,,,,,your pcm works with volts...FWIW your car is old and has been subjected to extreme heat in enginge bay area,,,most of the wiring has to be brittle by now,,,,
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
9
1995 5.0 just cranks
  • 9GT5
  • Jun 29, 2025
1994 - 1995 Specific Tech Jun 29, 2025
AeroCoupe
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
