code 34
antman
Killa Kali
My stang has been riding perfect for years and I just replaced the ACT and cleaned the TB and now i have a hanging idle. ran codes and now I have code 34.I replaced the IAC and cleaned the EGR and it seemed fine the pintle went in and out with ease but still have the idle problem.Any help appreciated.
88 gt 5 speed :shrug:
Ford foot notes .was code 84 also present?code 34 indicates that the egr valve and/or evp sensor is not fully seated in the closed position.because of the preload on the installed evp sensor,it is difficult to determine whether the egr valve is seated or the evp sensor is in contact with the egr valve stem.84 would be egr on/off control .vacuum leak or restriction .not plug in stuff like that.
i had the same code for a while i tried cleaning the egr and even swapped it for one i had laying around.finnaly bought anew valve and sensor (ford units from ebay)and it went away. phil
